Old 05-04-2003, 09:52 PM   #16
Is there a difference between a schottky diode and a power capicitor? If so wich would be more apropriate for a gm v12.
midnight oil is offline   Reply With Quote
Old 05-05-2003, 12:19 AM   #17
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Actually you need both.
minicooper is offline   Reply With Quote
Old 05-05-2003, 03:01 AM   #18
The powercap is not as important as the shottky, the powercap just gives you more punch. but if you are driving in the stock class it might be good to use one..
Hatebreed is offline   Reply With Quote
Old 05-05-2003, 08:09 AM   #19
Cool then I'll get both.
Thanks everyone for all the useful feedback
Old 05-05-2003, 08:53 AM   #20
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I dont know why, but I thought you were running a Novak ESC where it really doesnt make a difference if you run a shotky or not. The capacitor is a must though, helps punch, and prevents glitching.
Old 05-05-2003, 09:06 AM   #21
I have all the capicitors on the motor but i'm going to get a power capicitor and the schottky diode just to be on the safe side. Does the power capicitor replace the regular capicitors?
Old 05-05-2003, 03:42 PM   #22
minicooper's Avatar
You'll need the ones that attach to the motor from + to can, - to can and then one from + to - Some of the new motors already have them installed like the P2k's, Monsters, P2k2' and a few others on those you can skip that. All you need then would be the Schottky diodes, and power capacitors.
Schottky Diode SMOKESHOW86 Electric On-Road 1 11-08-2007 09:40 PM
What does a schottky diode do? MK_Arbiter Electric On-Road 36 04-11-2007 07:07 AM
schottky diode? aus jd 2703 Electric On-Road 5 03-05-2007 08:45 PM
schottky diode ????? drx Rookie Zone 2 04-29-2004 04:17 PM
schottky diode xxxtracer32 Electric Off-Road 2 10-20-2003 12:43 AM
