Old 07-26-2007, 12:47 PM   #1
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Default Anyone make a 3 pole connector suitable for brushless motors?
Switching motors out is butchering my wires and makes them hard to fit back in the holes. Just seeing if anyone has a nice clean solution for this.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 07-26-2007, 01:55 PM   #2
If you are running the novak motors, they've released an end bell a little over a year ago that solves this issue, but I don't think there are any other manufacturers of brushless motors that have caught on.
Laterilus is offline   Reply With Quote
Old 07-26-2007, 02:08 PM   #3
Trader Rating: 20 (100%+)
What about this plug.
http://www2.towerhobbies.com/cgi-bin...&I=LXHEB5&P=ML
hippie is offline   Reply With Quote
Old 07-26-2007, 02:41 PM   #4
xtremelimits285's Avatar
Send a message via MSN to xtremelimits285
Originally Posted by hippie View Post
that would work.....
i just wish they made lil bigger ones, for more amps an 12gadge wire..... i would use it on my rc10t3, but i think its too small for my 1/8th scale 8ight T with my Neu 1515 1y
Gary Antonietti
Losi Eight T - Monster Mamba v2 - Neu 1515 1y/f - Hyperion 4s 6500mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 Servo - 14/46t Gearing
- www.rc-monster.com - www.rcproductdesigns.com - www.teknorc.com - www.rclipos.com - www.teamlosi.com - www.castlecreations.com -
xtremelimits285 is offline   Reply With Quote
Old 07-26-2007, 05:10 PM   #5
TechWun's Avatar
Send a message via AIM to TechWun Send a message via MSN to TechWun Send a message via Yahoo to TechWun
The aforementioned connectors are good for 50 amps. Duratrax power poles are good for 60 and you can stack individuals as they interlock. So you could make a 3 pole connector out of three of them. That help any?
http://www.duratrax.com/caraccys/dtxc2300.html
- Matt
Current Models/Projects: Kyosho Optima Mid, Kyosho Shadow, RC10T4, RC10 truck conversion, Tamiya Clodbuster, Bolink Eliminator Sport
TechWun is offline   Reply With Quote
Old 07-26-2007, 05:28 PM   #6
cfwdude's Avatar
i would just replace your motor wires from time to time.
Especially if you're running a powerful brushless setup. Eliminate connectors wherever possible.
cfwdude is offline   Reply With Quote
Old 07-26-2007, 06:05 PM   #7
ta_man's Avatar
Trader Rating: 151 (100%+)
Default 3 pole connector
I've used Powerpoles on one of my cars to make a three pole connector and it works fine but they take up a lot of room.
I had seen people taking two Deans plugs and chopping one pin off and gluing them together to make a three pin connector. I tried that, but the problem was when you wanted to make the next end it was hard to match up.
What I am doing now is using the Dualsky brand Deans clones (avaiable on eBay for $2/pair or less from hothelisales) and using one complete pair on the motor and one complete pair on the ESC. So I solder two wires from the motor to a male end and one wire from the motor to a female end. Then I solder two wires from the ESC to a female end and one wire from the ESC to a maile end. This has the advantage of using one whole pair for each motor or speedo with no extras left over. I didn't bother trying to glue them together. In the end, I couldn't see a need for that.
Having bought a bunch of the Dualsky connectors, my cost was about $1.70/pair. For $3.40 I have a motor and ESC set up and each additional motor is only $1.70. Much more eceonomical than the Astroflight for $13.79.
ta_man is offline   Reply With Quote
Old 07-26-2007, 07:25 PM   #8
RodneyB's Avatar
I used the AstroFlight connector to regularly switch between a Novak 6.5 and 13.5 in my T4 and it worked fine. I recently went through a phase where I tried to reduce the amount of equipment I brought to the track so it was bye-bye hard wiring. I thought the connector was a little heavy though. The other thing is that this connector is not keyed, so you could put it in backwards if you are not careful. The way I have it wired, I'd really have to twist the connector to do that, but it's still possible. Here it is in the truck.
RodneyB is offline   Reply With Quote
Old 07-26-2007, 07:50 PM   #9
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Thats a very nice wiring job.
I'm impressed, good job.
UN4RACING is offline   Reply With Quote
Old 07-26-2007, 09:16 PM   #10
RodneyB's Avatar
Thanks!
Old 07-26-2007, 10:51 PM   #11
action135's Avatar
if your using mamba you can use a deans connector on the pos. and neg. and just tie back the white wire while using brushed.
action135 is offline   Reply With Quote
Suitable brushless motors for an E-Savage poorbie:( Radio and Electronics 2 10-16-2007 11:40 PM
Does LRP make a 10.5 Brushless and if so where can I get one in the US John Malin Electric On-Road 0 07-16-2007 02:15 PM
f/s 7 reedy motors complete.. make me a offer on pm.. ctmazzo R/C Items: For Sale/Trade 2 06-28-2007 09:47 AM
Corally style connector for motors? lookinco Electric On-Road 16 01-07-2006 11:10 PM
How Do You Make A Pole? supra528 Chat Lounge 4 05-11-2003 08:58 PM
