Old 07-29-2007, 04:53 PM   #16
ta_man's Avatar
Trader Rating: 151 (100%+)
Originally Posted by Sneaky Pete View Post
I've heard that too but not from anyone from Castle. :-( That would be huge!
I think they have been promising that "soon" for 6-8 months. Kind of like the Mamba Monster Maxx.
ta_man is online now   Reply With Quote
Old 07-29-2007, 06:21 PM   #17
Moderator
badaml's Avatar
Trader Rating: 127 (100%+)
I emailed caste to ask if the novak velociti motors could be used with the mamba max and they said no, but they were working on software to allow this.
badaml is offline   Reply With Quote
Old 07-29-2007, 11:11 PM   #18
jk racing's Avatar
Trader Rating: 20 (100%+)
I have both, a 4600 & 6.5 GTB. It is very hard to compare the two because they are very different. If you spin and roll backwards with the GTB, no issue, nail the throttle and go, the Mamba will hesitate. Smoother is a realtive term also, it would have to be tested with similar KV motors, same car, same battery pack, same track & conditions and 2 back to back runs by the same driver. I personally like the 4600, it is easier to drive for me, and the Castle Link software lets me customize the speedo any way I like.
--Joey--
Venom Batteries & Chargers
Old School Racer & Vintage RC Car nut
jk racing is offline   Reply With Quote
Old 08-02-2007, 08:47 PM   #19
Sneaky Pete's Avatar
Gearing my MF2 at 21/86 worked great but I ran into a couple snags.
During the main, I almost got rear ended at the start because there was a noticable delay before the motor spun and after running a 7min main, the ESC was about 165'F. The motor was only about 105'F.
What can I do prevent delays from a standstill? I have start power set to high and running a ton of forward throttle trim.
Does anyone know what at temp the ESC will shut off?
Sneaky Pete is offline   Reply With Quote
Old 08-02-2007, 09:44 PM   #20
badassrevo's Avatar
Have you tried the start power on low? it worked for me. The speedo shuts down at 200. run a black Novak 25mm fan on the heat sink. You can attach it with 4-40 screws.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 08-03-2007, 12:34 AM   #21
cfwdude's Avatar
I've ran my Mamba ESC over 200, no shutdown. If I remember right, it hit 212. I'll have to check that old post...
It was on a TC, temps were taken about halfway through a 12 minute run.
cfwdude is offline   Reply With Quote
Old 08-03-2007, 05:58 AM   #22
Thanks for the info!
If I want to run a fan, how should I wire it? I'm using a personal transponder so my Aux/3rd Channel is occupied. Can I wire it directly to the battery?
Old 08-03-2007, 06:33 AM   #23
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
The Mamba is designed to run hotter for what ever reason. Novak's thermal protection shut down, if I remember correctly is 180.
S' pete
If the esc is that much hotter than the motor, it could be the battery, but in your case its probally the mix mached components.
165 is fine for a Novak ESC and Motor to run, and they actually recomend that tempature range in the instructions when you buy the GTB/Velocity or SS combo. But with a stock 13.5 ss (27t) the temps should not vary that much, between the motor and esc.
The difference in your situation is the Mamba and Novak were not designed to be interchangeable, even though they are similar and it seems to be working, kind of.
If it were me, I would sell either the ESC or the Motor. Which ever one you decide to keep, buy the matching component. You will have no worries, and every thing will work as they were orgionally designed. - Just my .02
Run the cooling fan as well.
OG RC 10T is offline   Reply With Quote
Old 08-03-2007, 01:01 PM   #24
Hey, I read that if the MM esc is hotter then the motor that you are likely under geared , motor gets hotter then you are over geared. That said i would not know about how different the 2 companies motors will re-act. Dan.
danimal1965 is offline   Reply With Quote
Brushless motor for Mamba Max ESC Yoshimura Radio and Electronics 10 03-20-2008 10:47 PM
Will LRP Brushless ESC work with Novak BL Motors? LOSI123 Electric On-Road 2 09-22-2007 07:37 PM
lookin for any brushless motor that can work with a mamba max esc cm367700 R/C Items: Wanted to Buy 6 09-19-2007 05:22 PM
Big brushless sale-Novak and Mamba Max! DrOlds R/C Items: For Sale/Trade 24 06-01-2007 04:09 PM
FT Mamba Max Systems for Novak, LRP, or other Brushless mattnin R/C Items: For Sale/Trade 13 05-09-2007 06:36 PM
