Old 07-23-2007, 09:09 PM   #1
annie_himself's Avatar
Send a message via AIM to annie_himself
Default LRP v7.1 Digital ESC Problems
I have it in my Losi and wired to a Trinity Speed Gems 12t motor. I think the ESC may be bad or the brushes might be getting stuck on the comm. The ESC basically runs when it wants to or so it seems.
annie_himself is offline   Reply With Quote
Old 07-24-2007, 12:41 AM   #2
if you try shaking your car of if you try to spin the wheels to rotate the motor, and it works then it's probably the brushes, try to cut your comm, clean your motor and your brush hoods and get new brushes you should be up and running again no problems.
imel24 is offline   Reply With Quote
Old 07-24-2007, 08:03 AM   #3
How would I go about cleaning the brush hoods?
Old 07-24-2007, 08:52 AM   #4
T. Mertz's Avatar
Send a message via AIM to T. Mertz
When your having these problems, there could be something binding in the brush hood which isnt letting the brushes have a good connection against the commutator. Just take your motor out, endbell off and take the washers off each side of the motor shaft. Then you cut the motor, clean that up, then you can spray some motor spray in the motor can towards the bearing, also in the endbell where the brush hoods are. Before you put the motor in, just make sure there isnt anything in the brush hood that could be causing your problem, and get some new brushes in there. Sometimes there can be solder that might have gotten in there. Make sure you put the washers back on both ends of the motor shaft and dont forget to re-oil the bearings. You should break in your motor for about 2 or 3 minutes. This should solve your problem, if not try re-setting your speed-control. Hope this helps.
Tim Mertz
Team Orion/Team Young Gunz!/BIG Johnson Paints/Long Island Raceway & Hobby
T. Mertz is offline   Reply With Quote
Old 07-24-2007, 10:02 AM   #5
I can't really just cut my motor but I will see what I can do. Thanks.
Old 07-25-2007, 01:20 AM   #6
T. Mertz's Avatar
Yeah i thought that you were maybe racing at a track where almost everyone has a motor lathe.
Tim Mertz
Old 07-25-2007, 08:12 AM   #7
No siree.
Duratrax Piranha Digital Charger problems Chris__RC Electric Off-Road 2 07-01-2008 11:28 AM
FUTABA Servos Digital Brushless BLS451 and Digital S9351 SCUBA STEVE R/C Items: For Sale/Trade 8 11-11-2007 06:18 PM
Hitec 925MG, 625MG servos, digital or non digital Cain R/C Items: Wanted to Buy 2 03-09-2007 03:17 PM
Sony digital camera and digital camcorder for sale Danpatinod Other Items: For Sale/Trade or Wanted to Buy 0 12-28-2005 08:00 PM
Any problems with a digital servo on throttle? Wildewinds Nitro On-Road 1 10-05-2004 05:55 AM
