Old 07-19-2007, 07:50 AM   #1
badassrevo's Avatar
Default NEW XXXT CR
http://www.ultimaterc.com/forums/showthread.php?t=81351
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-19-2007, 07:53 AM   #2
memyselfandI's Avatar
very nice I cannot wait to get one
Carisma Racing Australia
Modelflight.com.au
Team AKA
Ryper Hobbies
memyselfandI is offline   Reply With Quote
Old 07-19-2007, 07:55 AM   #3
badassrevo's Avatar
Overview
From the world-renowned engineers at Team Losi Racing, who have been developing revolutionary race-winning vehicles for over 25 years, comes the latest track tested, Competition- Ready (CR ) 2WD electric truck.
The XXX-T CR continues TeamLosi Racing’s tradition of offering racers the most innovative designs and top-of-the-line features available. The Team Losi Racing development team has worked long and hard to refine and redesign where needed to take full advantage of the latest hi-output batteries and hi-performance tech motors. This makes it easier for even the average driver to turn faster times, lap after lap. Additionally, the XXX-T CR represents the latest developments in material composition for more durability than any truck you’ve ever driven. The XXX-T CR is one of the most technologically advanced race trucks ever developed, and further demonstrates Team Losi Racing’s commitment to putting racers 1st.
Key Features in detail:
Quick Change Aluminum Rear Hubs
The XXX-T CR uses the same wheels on the front and rear, and features quick release rear axles that let you swap old tread for new in seconds. The same wheels can be used on the front axles using a standard wheel nut configuration. This marks the first time that both of these features have been offered on any 1/10-scale 2WD electric truck. In addition, the new aluminum, multi-adjustable rear hubs give the XXT-CR the most tunable suspension in electric truck racing. The hubs include oversized rear axle bearings for maximum durability.
Proven XXX Transmission
Positioning the weight low and forward, close to the center of gravity, provides the XXX-T CR with greater forward traction and a lower polar moment than other vehicles. The Kevlar® Spur gear, machined motor plate, motor guard and the race-proven double disk slipper are capable of handling the hottest motors smoothly and efficiently. The redesigned, long-life ball differential offers more consistent handling with less maintenance required. A new molded gear cover protects the drivetrain components by sealing out dirt and debris, while the fan mount allows for the addition of an optional fan to keep hot modified or brushless motors running cool.
Variable Length Arms
Variable length arms give racers the ability to switch between long and short positions, allowing you to change the handling characteristics for a wide range of driving styles and track conditions. The result is tuning versatility that is simply unmatched by any competitor.
Exclusive EA3 class composites
Developed for the ultimate combination of low weight and incredible durability, critical components on the XXX-T CR are made from Team Losi Racing’s exclusive EA3 class composite. These compounds not only provide added impact protection but also improve handling on the widest variety of tracks, delivering the precision feel that racers demand.
Extra Long Chassis
The Team Losi Racing engineering and development team have refined and revised the overall balance of the XXX-T CR by extending the chassis an additional .200”. In combination with the suspension geometry of the XXX-T CR, the extended chassis allows it to produce incredible acceleration and stability through the roughest track sections and tightest turns.. This also allows the XXX-T CR to take full advantage of the latest generation of hi-performance motors, batteries, and tires. This results in predictable handling, making the XXX-T CR even easier to drive fast.
Titanium Nitrided Hinge Pins
Titanium Nitride (TiNi) hinge pins are used throughout the XXX-T CR. The combination of hardness and lubricity reduces friction for super-smooth suspension operation without sacrificing strength. The increased surface hardness offers additional wear resistance and greater durability in the worst conditions. Additionally, the shock shafts are also TiNi coated for smooth, consistent handling and durability.
New Steel Alloy Adjustable Front Axles
The steel alloy adjustable front axles allow the use of the same wheels front and rear while offering the ability to adjust the width for even more tuning options.
Key Features
Extra Long Chassis
Fan Motor Mount For Engine Cooling
Specs
Type: Electric Race Truck
Scale: 1/10
Length: 16.395 in (416.43mm)
Width: 12.725 in (323.22mm)
Wheelbase: 11.250 in (285.75mm)
Weight: Varies
Chassis: Team Losi Racing's EA3 composite
Suspension: 4-wheel independent
Drive Train: Sealed, 3-gear transmission
Shock Type: Hard-anodixed threaded aluminum, oil-filled, Ti-Ni shafts
Body: Clear polycarbonate
Ball Bearings: Complete
Needed to Complete
6-cell battery pack
charger
motor w/pinion gear
2 channel surface radio system w/steering servo
electronic speed control
modeling tools
polycarbonate-compatible paint
LOSK0077 $254.99
Doug Lightcap
Old 07-19-2007, 07:58 AM   #4
annie_himself's Avatar
Send a message via AIM to annie_himself
Maybe they saw the Worlds thread.
annie_himself is offline   Reply With Quote
Old 07-19-2007, 08:53 AM   #5
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
Looks nice...hopefully they dont have first batch EA3 problems like with the other 2 cars. Also it looks like there's a fan mount for the motor on there. And last, where did they get this info, as I dont see it on the Losi site.
D Hunt 3 is offline   Reply With Quote
Old 07-19-2007, 08:58 AM   #6
Trader Rating: 28 (100%+)
Not bad for a company who gave up on electric racing...
(referring to the worlds thread)
FlyByWire is offline   Reply With Quote
Old 07-19-2007, 09:41 AM   #7
Send a message via MSN to k£v!n
I wouldn't say they gave up on electric all together just buggy's
k£v!n is offline   Reply With Quote
Old 07-19-2007, 09:43 AM   #8
sport10's Avatar
Yea, in the last two years the only thing they have not introduced is a new 4wd electric. I would say they are still pretty active in electric racing.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 07-19-2007, 10:15 AM   #9
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
All they did with the truck is the same thing they did with the buggy, take the last 2 generations of cars/trucks, and combined parts to make something used, i mean new.. Ive heard from a few diff people that had the last 2 losi cars, and said it made really no difference at all..
jabroni racing is offline   Reply With Quote
Old 07-19-2007, 10:18 AM   #10
Tim W.'s Avatar
I wonder when it will come out? I cant wait to get the longer chassis and new quick change rear hubs for my mf1 hybrid so I can use my Ad2 tires and rims.
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 07-19-2007, 10:18 AM   #11
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
At least they did get something kind of new out there.
Maybe this will help get some more guys into trucks who have been waiting for the new truck after having the XXX-TCR, etc.
I just really hope they have solved there teething problems with the composite material.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 07-19-2007, 10:24 AM   #12
Maxxwalla's Avatar
go HERE on their site.
Maxxwalla is offline   Reply With Quote
Old 07-19-2007, 10:24 AM   #13
scott54's Avatar
Well this is good news, it's basically all the hop ups that everyone's been trying to do anyway. I already called my lhs and they have it listed on their ordering website but it says not yet available. It's not on teamlosi.com but it's on horizonhobby.com for $254 and listed as "out of stock, item can be back ordered". Also, not that it matters, it's listed as LOSI with the new LOSI logo, not Team Losi... .... hmmm
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Old 07-19-2007, 10:35 AM   #14
Maxxwalla's Avatar
The rear hubs look cool. What's that extra hole for
Old 07-19-2007, 10:37 AM   #15
scott54's Avatar
I just got off the phone with Horizon, estimated availability is late September.
XXXT MF/CR inman59 R/C Items: For Sale/Trade 7 11-27-2007 03:16 PM
XXXT MF/CR inman59 R/C Items: For Sale/Trade 4 11-26-2007 06:37 PM
xxxt-cr deedit R/C Items: For Sale/Trade 13 11-21-2007 04:31 PM
wtb xxxt revoboyz R/C Items: Wanted to Buy 4 07-16-2006 01:46 PM
Mf Xxxt Tres R/C Items: For Sale/Trade 9 12-21-2003 03:05 PM
