Old 07-14-2007, 12:40 PM   #1
streetracer745's Avatar
Send a message via AIM to streetracer745
Default timing on a modified motor? whats it do?
how does timing affect a motors performance? i was pretty sure that a higher timing gave you more torque, but im not sure. could anyone confirm this for me? thanks
streetracer745 is offline   Reply With Quote
Old 07-14-2007, 04:33 PM   #2
Scrubb's Avatar
moves the powerband around.
More timing gives less torque, more rpm. Less timing gives more torque, less rpm.
Big tracks use less timing and bigger pinions, smaller tracks use more timing and smaller pinions.
Higher winds like 15 turn motors use higher timing, lower winds like 9 turns use less timing.
Thats the simplified version, The "Big Jims Motor Forum" on the RCCARS.com website has more detailed information but you'll need to search for it.
Scrubb is offline   Reply With Quote
Old 07-14-2007, 05:00 PM   #3
thanks man thats what i needed to hear.
Old 07-14-2007, 06:58 PM   #4
WheelNut's Avatar
Send a message via MSN to WheelNut
Increased timing will also increase the amount of wear you see on your brushes and comm, and it will also give you more drag brake. Usually I will just use the timing on my motor to adjust the drag brake instead of changing the ESC settings since its faster to just give the endbell a little twist than have to go through all kinds of stupid programming steps.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 07-14-2007, 07:05 PM   #5
well im going to be lowering the turn since that will give me a little more torque. i need a slight bit more i think. not quite the acceleration i want
Timing you pit stops in longer mains, whats your method? pracy Nitro Off-Road 6 06-19-2008 10:15 AM
Difference b/tween ESC timing and timing on motor? Loverc Electric On-Road 8 04-11-2008 05:45 PM
any article on modified timing tc3 racer sc Electric On-Road 3 07-05-2004 11:14 AM
Modified Motor Timing Mitch Australian Racing 3 09-03-2003 06:10 AM
Modified timing Cole Trickle Electric On-Road 3 07-17-2003 06:20 AM
