Old 07-13-2007, 06:51 PM   #16
badassrevo's Avatar
I got this from the castle web site.
4. My ESC may or may not arm, but it will not calibrate to my transmitter.
Most calibration issues can be solved by settings on the transmitter. Make sure you have both your throttle and brake endpoints (called EPA or ATV on your radio) on the throttle channel out to 100 to 120%. If you have a Futaba or Futaba made transmitter, set the throttle channel to the reversed position.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-13-2007, 06:51 PM   #17
badassrevo's Avatar
Doug Lightcap
Old 07-13-2007, 07:17 PM   #18
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
You have to make sure you hold the throttle longer than you would think is necessary. That is what I had to do on my Mamba max.
I ran a 5700 unit in my T4, was just the right amount of pop.
I didn't experience the cogging after I adjusted it some. Increased the max power draw ( i think that is what it was basically), different than I thought I would do and it went away. I have also heard of people removing the plugs and the stuttering going away, however, I am not sure if that voids the warranty?
Thing I didn't like:
1. Placement of dataport for pc hookup limited direction of mounting the ESC
2. 5V bec, want 6V for my servos.
Good ESC other than that for the money.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 07-13-2007, 07:18 PM   #19
Trader Rating: 32 (100%+)
Send a message via AIM to JDCrow Send a message via Skype™ to JDCrow
Tried that.
Nomadio set EPA to 125 and tried Normal and Reverse settings.
JDCrow is offline   Reply With Quote
Old 07-13-2007, 08:07 PM   #20
jk racing's Avatar
Trader Rating: 20 (100%+)
I have both a GTB (6.5) and the MM 4600, when I ran them back to back in my 4wd cars, the 6.5 had better overall speed. Gearing does play a part in it. I think the MM is easier to drive, "smoother". I dont have cogging issues.
Oh, I have run Novak stuff for many years (almost 20), but my GTB eats fans.
--Joey--
Venom Batteries & Chargers
Old School Racer & Vintage RC Car nut
jk racing is offline   Reply With Quote
Old 07-14-2007, 07:48 AM   #21
Alltapdout's Avatar
Fan<-------GTB "Umm, I'm hungry"
Alltapdout is offline   Reply With Quote
Old 07-14-2007, 08:33 AM   #22
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Talking 1/10th off road racing 2 wheel drive.
Over a year and still running the stock fan on my GTB. Dirt racing and carpet.
Keep the wires out of it and they last just fine.
Mamba is the bashers best friend.
And GTB is the racers best friend.
Also with the mamba you need a computer to program it. And In a dirt environment that sucks. More suitable for carpet racing. Thats where mines going to get used this winter. I haven't give'n up on it entirely yet.
Oh and wait till you crash and roll backwards you will have to wait for it to stop rolling before you can go forward.
It appears the MM is suitable for High out put applications like 1/8the electric.
Novak pick your plug and play.
MM redo the plugs. Get a computer down load 3.0 program it and then spend the rest of your life trying to figure out how to get the stutter out on the take off or even get the hesitation out on power coming out of a turn.
And don't crash and roll backwards on a jump in the heat of battle, you'll fall 5 seconds behind. In one little foble.
UN4RACING is offline   Reply With Quote
Old 07-19-2007, 10:33 AM   #23
Tech Legend
Cain's Avatar
I haven't had the issue of not being able to configure it without a PC. There are alot of settings in it that you can adjust, pretty much everything I think without a PC, you just don't get to do it in very little increments like 1% for this, 1% for that, instead its like 10%.
Put it this way, my last 5700 I got the stutter gone using only the manual configuration options, no PC input.
One other thing about the mamba that can be tricky, they say that you need to hear X amount of beeps (or flashes is it?, from memory here) to know what setting your on. The last setting however only flashes / beeps once.
Picked up another 5700 based on my previous experiences for my B4.
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 06:19 PM
Mamba 4200 + Mamba 25 Shawner85 R/C Items: For Sale/Trade 0 01-30-2008 05:54 PM
Mamba 5400 with mamba 25 esc for sale josh the 2nd R/C Items: For Sale/Trade 4 01-14-2007 04:11 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 10:59 AM
Mamba 8000/Mamba 25 esc coolkide R/C Items: For Sale/Trade 11 12-23-2004 05:48 PM
