Old 07-12-2007, 10:59 AM   #1
larlee's Avatar
Send a message via MSN to larlee Send a message via Yahoo to larlee
Default DF03 Setup
Hi,
Does anyone has some advice on setup for DF03 running on clement flooring? it is slightly rough not the smooth type. i broke quite a few parts and destory a couple sport tuned motor during the tamiya race. we have ramps and i am using the alum shocks with the setup shown on the sheet and it keeps bottoming.
Not too sure whether is there a front one way or centre one way kit. Do we really need it? My car runs understeer and always loses momentum during the turns.
Please advice.
Thanks.
larlee is offline   Reply With Quote
Old 07-14-2007, 12:19 PM   #2
streetracer745's Avatar
Send a message via AIM to streetracer745
there is both a center and front one-way. im ordering a front soon for mine. the stock suspension on the df03 is soft. even on the aluminum shocks. use slightly heavier springs and thicker oil. it will be better. a slipper will be good too. tamiya makes a kit for that as well
streetracer745 is offline   Reply With Quote
Old 07-14-2007, 02:17 PM   #3
how did you spoil the sport tuned motor?
you can use the Tamiya TRF shock piston to replace the with what you have from the shock kit. the holes are smaller and handles better.
i did that to mine, on all 4 shocks.
My Wheels...
DB-01/DT-02/DF-03/M-03R/HotShot/Boomerang/Hornet/Frog/Wild Willy2
Toonz is offline   Reply With Quote
Old 07-14-2007, 03:54 PM   #4
yeah i havent fried any motors yet.... thats weird
Old 07-16-2007, 12:22 PM   #5
larlee's Avatar
i didnt fried mine, i was following the setup instruction for the alu shocks. didnt get much time to test and it bottom real hard on the jumps....the magnets broke to pieces for the sports tuned.
i have changed the pistons to the smaller holes.
how many holes did you used? 2 holes for both front and back? how about oil? which position did u mount your shocks to for both front and back?
Old 07-16-2007, 01:00 PM   #6
did u get the TRF pistons? they are much better.
i use 2-holes and 40 oil all round.
front shock position
top centre hole
bottom 2nd hole from inside
rear shock position
top centre hole
bottom innermost hole
these are my preference so you may want to experiment the different mounting position to suit the track
by the way, how high did u jump and land? where is the tamiya race? RCI?
My Wheels...
Old 07-17-2007, 09:54 AM   #7
Bugs Bunny's Avatar
Hi guys, Im using e TRF shocks for the DF-03. Im using tamiya 800 shock oil for both front & rear with 2 pistons hole & middle spring. Below is a pic of my DF-03. The one in green.
Bugs Bunny is offline   Reply With Quote
Old 07-17-2007, 10:20 AM   #8
larlee's Avatar
top centre hole
rear shock position
top centre hole
last year the race is conducted in a shopping mall, Marina Square. Ramp is 1 metre high up and down.
Old 07-17-2007, 10:28 AM   #9
1 meter in height??? that's high..........
well just hope that you will get around to a better setting and keep the DF03 alive and running..it's a great car
My Wheels...
Old 07-17-2007, 12:31 PM   #10
larlee's Avatar
by right, if you control it right, it will land on the downslope but due to first time in race and was actually panic....i landed flat on the carpet a couple of times at the 1metre height which ended up with 3 sport tuned magnets cracked.
this race will not have a 1 metre ramp, but i would like to prevent slamming flat on the clement floor to damage anymore parts.
Old 07-17-2007, 07:39 PM   #11
i see. i thought it was a 1 meter high landing and that will really burst all the cars. otherwise the sport tuned is quite a bullet proof motor.
maybe you can also consider getting some aluminium and CF parts for the DF03 from 3racing.
My Wheels...
Old 07-19-2007, 11:27 AM   #12
larlee's Avatar
I saw those parts from 3Racing but cant use them in Tamiya races...
Old 07-23-2007, 02:37 PM   #13
yall are using the stock sport tuned motors? mine was terribly slow and i hated it personally. it couldnt even make it around the track
WTT DF03 Buggy for TA05 or Similar nexxus Australia For Sale/Trade 7 09-02-2009 11:12 PM
DF03 brushless gearing dharvin Electric Off-Road 4 03-01-2008 10:40 PM
FS: DF03 + hopups J-PaP Australia For Sale/Trade 3 04-25-2007 02:22 AM
wtb:tamiya dt02, df02, df03 J-PaP Australia Wanted to Buy 0 03-08-2007 05:30 AM
* TAMIYA DARK IMPACT 4WD BUGGY / DF03 ARR F/S * in2deep R/C Items: For Sale/Trade 20 01-12-2007 07:13 PM
