Old 11-30-2007, 09:28 AM   #31
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Yeah, those are my Lipo plates. I am getting another run of them made up next week. They will be 1mm narrower and a few mm longer (to suit more cars). Weight should be the same (4.5oz). Here are pics of them again. I think they will be $15 shipped, but I gotta see how much they run me still.
Edit: It's O.C.D. Tuning not OCM....as in Obsessive Compulsive Disorder...which my wife says I have with this R/C stuff!
Adding weight for Lipos-dsc02394.jpg   Adding weight for Lipos-dsc02396.jpg   Adding weight for Lipos-dsc02398.jpg
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 11-30-2007, 11:22 AM   #32
Suspended
I have an Orion 3600 on backorder and I'm going to use these tungsten weights with it:
http://www.maximum-velocity.com/tungstenplates.htm
I plan to stick 6 of them (4.5 oz) underneath the battery with servo tape. I'll let you all know how it works out.
Matt Buggy is offline   Reply With Quote
Old 11-30-2007, 03:15 PM   #33
Trader Rating: 42 (100%+)
Originally Posted by UN4RACING View Post
Here it is miket3............
I bet you thought I forgot you.
thanks
I'm amazed at the weight added. I just started to do this last weekend at Washtenaw and the truck was improving. I will definatly be adding more when we go back outside to our loose slippery off road track.
here's the web site in case anyone is interested.
embassyraceway.com
miket3 is offline   Reply With Quote
Old 01-01-2008, 12:44 PM   #34
slakr's Avatar
Trader Rating: 33 (100%+)
How can I get a few of those plates?
slakr is offline   Reply With Quote
Old 01-01-2008, 04:04 PM   #35
johnnyboy's Avatar
If anyone is looking for the OCD plates, I should have them any day now. The holidays really delayed things for me. Anyone interested shoot me a PM.
John
Old 01-01-2008, 06:13 PM   #36
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
I noticed that just adding the 5oz under the battery the buggy drove great (but the sprung weight still seemed alittle light, so adjusting ride height was needed)
I also noticed that adding the 5oz under the battery the truck drove ok, but had alittle extra push (after readjusting the ride height), believe dropping the front ride height down about 1mm below arms level would correct this.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 01-02-2008, 07:56 PM   #37
johnnyboy you have pm
camshaft is offline   Reply With Quote
Old 01-16-2008, 06:15 AM   #38
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
Originally Posted by F N CUDA View Post
What are you guys using to add the extra weight due to lite Lipos?
It's a huge difference and a lot of weight to add?
Whatever it is, I know it's gonna be big!
I don't understand why so many people think they need to add weight for lipos,
{unless your still using brushed motors and older lighter 3300 Nimh or smaller battery's},
I don't think people realize how much weight we have gained in the last couple of years, with larger and heavier Nimh battery's and heavier Brushless speed controllers and motors.
Here is what I have discovered on the scale.
Roar min. weight for 2wh buggy is 1499 grams or 3lbs 5oz.
Two years ago my BK2 with a 19T brushed motor and a LRP Q2 ESC and 3300 Nimh battery weighed 3lbs 7oz.
It handled great, and it was still over Roar min. wt. by 2oz.
With a 10.5 BL/motor and a LRP Spr/Comp. ESC. and a 4300 Nimh battery, it weighed 3lbs 12.5 oz.
So as you can see my 2wh. with BL and a 4300 Nimh battery gained 5.5oz.
Now with the same BL motor and ESC and a 6000mah Lipo battery it weighs 3lbs 7.8oz.
Which is only .8oz heavier than it was 2 years ago, which would then be 2.8oz over Roar min. wt.
Here's what I found in Truck.
Roar Min. weight for 2wh Truck is 60oz or 3lbs 13.4oz.
Two years ago my MF2 with a 19T brushed motor and a LRP Q2 ESC and a 3300 Nimh battery weighed 4lbs .Ooz.
It handled great, and it was still over Roar min. wt. by 2.6oz.
With a 10.5 BL. motor and Novak GTB ESC and 4300 Nimh battery, it weighed 4lbs 6.5oz.
So as you can see in 2 years my Trk. with BL and a 4300 Nimh battery gained 6.5oz.
Now with the same BL motor and ESC and a 6000mah Lipo battery it weighs 4lbs 2oz.
Which is only 2oz heavier than it was 2 years ago, which would then be 4.6oz over Roar min. wt.
I realize that there are smaller lighter Lipos , so the difference wont be as great , but I'm pretty sure you will still be above Roar min. wt. and not any heaver than what you weighed a couple of years ago.
So to sum it all up , if you were racing two years ago, and were happy with how you Truck or Buggy handled, and have gone Brushless , I would not recommend trying to add weight to compensate for the difference between your new Lipo battery and your old large capacity (over 3800) Nimh battery's.
Like in all motor sports the heavy the vehicle weighs the harder it is to accelerate , change direction and to stop.
All you need to do is go back to the set up that you use to run , or find a new one that works with the current BL/ Lipo weight.
Well that's my opinion for what it's worth.
Hi my name is Mike, and I'm a Chromeholic, my wheels have been chrome free for over a year, thanks to everyone who made fun of them.
*Chrominator* is offline   Reply With Quote
Old 01-16-2008, 08:05 AM   #39
johnnyboy's Avatar
I have tried the cars without...and with lighter settings also and found it just doesn't lay the power down the same and feels very whippy out on the track (especially in a saddle pack 4wd car).
Old 01-16-2008, 08:15 AM   #40
MustGoFaster's Avatar
When using a mod motor and/or on a loose track surface I have found cars to be un-drivable. While I agree reducing weight is the easiest way to go faster, there is a point of diminishing returns. Especially when using mod motors you will require a certain amount of weight in order to "put the power down".
MustGoFaster is offline   Reply With Quote
Old 01-16-2008, 09:30 AM   #41
Jason Pelletier's Avatar
My cars felt like doody with no weight in them, i saw some low speed turning advantages but in my lazer it pushes in one direction and the rb5 just doesnt feel planted. I ordered 2 ocd plates, they look nice and clean which is what i am all about. I have rc ocd as well my cars need to be perfect to my liking.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-16-2008, 12:34 PM   #42
crazyjr's Avatar
I have a B4, T4 and a academy sbv2 pro and never added weight to any of them. all over the minimum and handle great. I did add the 4 7 gram lead wieghts between the tower and rear bulk and two 7 gram lead weights to the rear triangles that is required on all associated B/T4's, but none with the lipo conversion
crazyjr is offline   Reply With Quote
Old 01-16-2008, 01:34 PM   #43
Orange's Avatar
I think it may be needed with a 3200/3600 just to make weight.... But personally, my truck weighs 62 ouces with a 4800 Platinum pack in it, I'm not going to add weight to it, I will just accomodate the setup for the change in weight...
I asked Ryan Maifield once what he did with a 5000mah Lipo, he said "I adjusted the ride height and punched it"
I like the weight savings.
Orange is offline   Reply With Quote
Weight balancing with Lipos mac853 Electric On-Road 29 09-15-2008 03:06 PM
Adding Weight to Chassis shaggys40oz Electric On-Road 7 10-20-2007 04:11 PM
Adding weight to Lipos? F N CUDA Electric On-Road 18 07-12-2007 01:11 AM
Adding weight to B4 Born2Lose Electric Off-Road 10 02-04-2007 04:36 PM
Adding Weight to the chassis TRF-Powered Electric On-Road 16 06-05-2003 11:27 PM
