Old 07-11-2007, 11:14 PM   #16
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Wild Cherry View Post
added ballast to equal a Gp3300 weight....
performance is awesome....
Nice wiring job. I like he way you put the servo wire threw the chassis.
UN4RACING is offline   Reply With Quote
Old 07-11-2007, 11:19 PM   #17
Tech Legend
Wild Cherry's Avatar
I should show pictures of it is now , it was brand new in those pictures ...
Already gone though two rebuild`s and its a bit dustier....
also I actually mangle those holes , remove the servo plug fro wires and then grind smaller holes...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 11-29-2007, 08:36 PM   #18
UN4RACING's Avatar
Here it is miket3............
I bet you thought I forgot you.
Old 11-29-2007, 08:45 PM   #19
Tony Newland's Avatar
Trader Rating: 50 (100%+)
I run a 1mm thick stainless plate under all my batteries....it weighs about 4.5oz
Schumacher Factory Team - Core RC - Tekin - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 11-29-2007, 09:05 PM   #20
UN4RACING's Avatar
What kit. And battery. That sounds like a perfect set up.
Old 11-29-2007, 09:17 PM   #21
I run the new GV2 Academy with a protek 4000 lipo
A guy in Canada made the plates and sold them for $14 shipped...
He's in the kyosho threads....OCM tuned or something like that
Sure makes it easy and clean, rather than duct taping crap all over my car
Old 11-29-2007, 09:40 PM   #22
I run an RB5 with 4800 lipo and don't add any weight, buggy handles great and jumps really well
_pilot_ is offline   Reply With Quote
Old 11-29-2007, 09:42 PM   #23
UN4RACING's Avatar
Thanks for the lead. Thats a good way to keep it uniform and the weight low.
I was running the XXXT with Max Amp 6000's. There was just enough room under the pack for some thing like that.
Old 11-29-2007, 09:44 PM   #24
UN4RACING's Avatar
Did you make any adjustments to the springs or oil or pistons to get the same feel or did it just react faster with less weight.?
I'm bet it jumped Higher.
Old 11-29-2007, 09:54 PM   #25
Davidka's Avatar
Trader Rating: 77 (100%+)
Lighter damping in the rear and lighter spring rate usually do it. The front usually does not require as much of a change on a 2wd car. Roar minimum weight is 52oz. for 2wd and 56oz. for 4wd. Most 2wd cars with NiMh cells come in between 3 and 6 oz over weight. My cars with GTb's and Orion 4800 packs weigh around 1oz over the limit with no weight added.
Old 11-29-2007, 10:26 PM   #26
UN4RACING's Avatar
Thats sweet.
I had to add weight to mine to keep it on the ground. Insane wheelies.
Old 11-29-2007, 10:32 PM   #27
MustGoFaster's Avatar
+1
I'm using the same one. (OCM / Johnnyboy)
Keeps the weight uniform and as someone mentioned you could put it under or over the battery.
MustGoFaster is offline   Reply With Quote
Old 11-29-2007, 10:33 PM   #28
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
The guy making the plates is "johnnyboy", who actually posted in this thread.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 11-29-2007, 10:38 PM   #29
Duh <smacked forehead>, I totally overlooked Johnny....sorry Johnny, I'll take another plate if you still have them
Old 11-30-2007, 12:12 AM   #30
In the rear I run Losi pink springs on new tires and Kyosho silver on worn tires and 30wt oil, for the front I run Kyosho silver springs and 25wt oil. I'm running a Mamba Max 6900 and race on a high grip indoor carpet offroad track. Rear tires are silver ifmar studs.
Weight balancing with Lipos mac853 Electric On-Road 29 09-15-2008 03:06 PM
Adding Weight to Chassis shaggys40oz Electric On-Road 7 10-20-2007 04:11 PM
Adding weight to Lipos? F N CUDA Electric On-Road 18 07-12-2007 01:11 AM
Adding weight to B4 Born2Lose Electric Off-Road 10 02-04-2007 04:36 PM
Adding Weight to the chassis TRF-Powered Electric On-Road 16 06-05-2003 11:27 PM
