Old 07-10-2007, 12:18 PM   #1
tenpins77's Avatar
Send a message via AIM to tenpins77
Cool how high can u jump?
hey all,
Running a money 19t in my buggy. Having some issues clearing a double at the local track? Runnin silver springs in the back, brown up front with 40lb shock oil in the front, and 35 in the back? Could the smaller motor be the issue, or the suspension?
thanks,
tenpins77
tenpins77 is offline   Reply With Quote
Old 07-10-2007, 01:41 PM   #2
annie_himself's Avatar
Send a message via AIM to annie_himself
Originally Posted by tenpins77 View Post
hey all,
thanks,
tenpins77
It could be your suspension or gearing, try a stiffer spring up front like a green or silver then if that doesn't work look at changing your gearing by taking the pinion down a few gears.
annie_himself is offline   Reply With Quote
Old 07-10-2007, 01:56 PM   #3
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
May need some more motor.
AxiomJacob is offline   Reply With Quote
Old 07-10-2007, 03:29 PM   #4
sport10's Avatar
Try gearing up a tooth or two on the money motor. It is a torque monster and likes higher gearing. Also, higher voltage battery packs will give extra punch too.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 07-10-2007, 06:12 PM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Roll It.
UN4RACING is offline   Reply With Quote
Old 07-10-2007, 06:53 PM   #6
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I wouldn't run that weight oil. Try 35 front and 30 rear with brown springs and greens in the rear.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 07-10-2007, 08:42 PM   #7
action135's Avatar
man..
try a lighter weight oil.
anywhere from 27-35 weight is good in a buggy.
action135 is offline   Reply With Quote
Old 07-10-2007, 10:22 PM   #8
Mason's Avatar
tenpins, we really need to know what type of material you are running on and how its prepped/maintained. We can give you a dozen things to try and you can spend a long while trying them all - which might not be a bad thing as that will give you an idea of what they do. But it may not get you any closer to your goal. so share some track info and then we can get you headed in the right direction.
also include tire/insert
Mason is online now   Reply With Quote
I like to jump joeling R/C Photography 12 01-03-2010 03:15 AM
new jump dan.zinger Monster Trucks 6 08-13-2008 11:54 PM
Best jump... EVER. smb17 Nitro Off-Road 20 07-17-2008 02:21 PM
Jump size? desertbird Electric Off-Road 25 05-12-2008 04:22 PM
How do YOU handle a Jump? Mr.Maim Electric Off-Road 22 04-07-2007 01:18 AM
