Old 06-18-2007, 01:38 PM   #1
Talking Losi XXX-T Diff Melt Down!
I am running a mm7700 in my xxx-t and I am going through diffs like a hot knife through butter. Any tips and tricks to setting it up so this dosn't keep happening. Once I build the diff I adjust it according to spec, and loosen up my slipper but than I don't like running my slipper so loose cause I loose to much off the line so I slowly tighten it down, runs good for a while and than zip, zoom and poof I got a nice melted diff. Do they make an aluminum upgrade? Is there such a thing as to tight of a rear diff?
Steak N Shake is offline   Reply With Quote
Old 06-18-2007, 01:51 PM   #2
sport10's Avatar
There is no spec on adjusting the diffs you have to check and see if it is slipping and adjust accordingly. The reason you are melting things is usually the diff is slipping. Also, just for good measure replace the outdrive bearings with some good sealed bearings. I have had a bad outdrive bearing cause this in the past too.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 06-18-2007, 08:19 PM   #3
Aaron Waldron's Avatar
If your diff is slipping, it's likely either that A) you're using too much diff lube, or B) you're not re-tightening the diff after it breaks in.
Build the diff with all stock parts (you can use AE black grease on the thrust, but it's not absolutely necessary) and as the instruction manual states. Use only enough diff lube to coat the diff balls once popped into the pockets in the gear. As you tighten the diff (1/4-1/2 at a time once the diff holds itself together) work the diff back and forth with your hands in between each turn with the screwdriver.
Tighten until the diff doesn't slip. Use an allen wrench in the slots of each outdrive to hold them still, and try to turn the diff gear. It shouldn't budge! If it does, the diff is slipping.
Put the assembled diff in your truck, set it on a car stand or a pair of tires, and apply enough throttle to get the tires turning. Hold one tire for 10-15 seconds (which will cause the truck to diff out to the other tire), and then the other tire, switching back and forth 4-5 times. Shut the truck off and tighten your slipper completely. Hold the right rear tire and the spur gear with your right hand and try to turn the left rear tire. It's probably going to turn (this means the diff broke in and loosened up). Tighten the diff in small increments until you can no longer turn the left rear tire using this test. Back the slipper off (usually about five full turns) until you can turn the left rear tire with some effort. You should see the slipper assembly (nut, spring, etc.) turn as you rotate the left rear tire. This guarantees that the slipper will break loose before the diff does, which will stop your diff from melting.
Check the diff every five minutes or so for the first few packs (in other words, don't go run a half hour on a brand new diff without checking it so it doesn't slip). After that, make it a habit to check that the slipper is slipping before the diff every time you go to run your truck. It takes 10 seconds and will save you from melting diffs.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-19-2007, 09:11 AM   #4
Dude Aaron, you are the man, that helps out a ton. It totally makes sense now why I melted it on Sunday. I didn't break it in at all. I slapped that baby together, used the right wheel and spur grab technique and than hit the durt hard and fast, I knew I should have double checked it while I was running. Thanks so much for your help, I'll be double and triple checking from now on!
Old 06-19-2007, 12:02 PM   #5
Glad I can help!
www.liverc.com
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 08:49 PM
Mid Summer Melt Down at the R.O.C.K Satish Canadian R/C Scene 101 09-05-2008 04:13 PM
Quick Question: Would ESC wires melt next to motor? or8ital Electric On-Road 6 02-01-2008 10:31 PM
plugs or melt on the motor? davioh Electric On-Road 16 04-20-2003 07:47 PM
heat shrink melt/cooling ScottPro2 Electric On-Road 8 11-02-2001 10:53 AM
