Old 06-15-2007, 11:26 PM   #1
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Default GTB users
Anyone ever use a different fan? I want to put one in FRONT of my ESC and blow it across like Maifield did in his B4. This will cut down on any clearance issues. I also want to put in a bigger (thicker) fan that will increase airflow, but my question for that is do I have to do anything different when connecting it to the esc, or can I just splice it in to what was on there now?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-16-2007, 01:12 AM   #2
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
I have this on my B4:
http://www.rcmart.com/catalog/produc...ducts_id=18406
This one can also be used... http://www.rcmart.com/catalog/produc...ducts_id=19683
They're plug and play
Hibernating...
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 06-16-2007, 01:37 AM   #3
K_King's Avatar
Yeah, the stock one is 30x30x7mm and it hits the body and lifts it up.
I ended up ordering this
Seems to be pretty fat would should mean more airflow. Hopefully its not tall.
Old 06-16-2007, 09:05 AM   #4
Trader Rating: 35 (100%+)
I have also used a computer fan. I bought one similar to this:
http://www.directron.com/ec3010m05ca.html . There was one fan I bought but I don't remember where I bought it from but it was very durable. Just do a search for 30mm x 30mm x (7mm to 10mm) 5V computer fans. Make sure it is 5V.
Also, a guy at the track uses the smaller black Novak fan too and he says that one is a bit more durable than the GTB fan.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 06-16-2007, 10:07 AM   #5
trebor's Avatar
Well I had to tell y'all what happened to me with a stock one. It ended up getting hung up on the body after a flip and all of the sudden about 20 sec. later my car was smoking, always a bad sign. Sure enough it was the lovely GTB (yeah,$180 smokin') sitting there melting away because the fan fin was jammed on the body. So now Im assed out of my baby GTB. So Im debating on getting a different ESC or stick with GTB and get a HD fan.
Does anybody put a piece of lexan on bottom of GTB then shrinkwrap it to be water resistant? If not then do it, It will save ya if ever a quick rainfall or accident.
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 06-16-2007, 10:22 AM   #6
K_King's Avatar
Shrinkwrap? Wouldnt that cut off any air to it at all?
Old 06-16-2007, 05:47 PM   #7
I use the Novak GTB Spread Spektrum ESC with a 5.5 sintered rotor motor in my AE T-4 truck in 20 minute mains all the time without the fan....I take it off because you don't need it with the sintered rotor.
Tomorrow the ROAR Nats will have a 20 minute Li-po Brushless race with Cavalairi, Maifield, Truhe, Perez, Easton with other factory sponsored racers...Novak and LRP/Orion is well represented along with Tekin's new brushless system including Peak/Orions, MaxAmps, Tekin and Checkpoint having li-po batteries with they're name on them.
Tune in tomorrow on www.liverc.com
Craps is offline   Reply With Quote
Old 06-16-2007, 06:07 PM   #8
K_King's Avatar
Well trucks prolly dont need one because the air can get in, and theres a lot of room. Im basically thinking about my CR. I am going to get a 7.5 sintered, and only running 19T or stock racing.
I will also be racing in 100+ degree temps I believe next Sunday at Hemet, CA. Then again in Saugus.
Old 06-17-2007, 09:10 AM   #9
cfwdude's Avatar
I don't use a fan in my B4, using a 5.5 motor with a sintered rotor.
20-25 minute runs, it's around 125 degrees.
I wouldn't change the heatsink. You want more fins, not larger gaps for cooling. The more surface area the heatsink has (more fins) the more efficient it will be at cooling.
cfwdude is offline   Reply With Quote
JR XS3 users help me scr_achy Electric Off-Road 1 03-03-2007 08:01 PM
Any R40 users here? Dodge_Stratus Singapore R/C Racers 0 01-18-2007 08:19 PM
G4S Users in jkt? Pierre1 Indonesia Racing 16 05-11-2006 08:26 AM
3PK users, pls help... rcprix Electric On-Road 9 11-02-2003 09:23 PM
LRP ESC users, help! huasze Singapore R/C Racers 4 12-27-2002 04:42 PM
