B4 setup help please >
Old 05-18-2007, 04:26 PM
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default B4 setup help please
I am looking for a good setup, or place to start with my B4... I have not been able to find anything I like.... The track is big (1/8 scale gas and Truggy) it is hard packed with loose stuff on top... traction is low, gets water but it is gone before it gets put down (heat and wind). The main problem is rear traction. The front turns good, but the rear just wants to come around with it.
Anyone have a good setup sheet they can post ?
Thanks for any and all help
SteveJa is offline
Old 05-18-2007, 04:29 PM
Matt Howard's Avatar
My XXX-CR is waiting for you Grant was rocking with his last weekend, wait till he get's some time with it
Matt Howard is offline
Old 05-18-2007, 04:39 PM
SteveJa's Avatar
I knew that you would find this post, and put something in here... Let me tell you, if I could sell my B4 for a good price I would be all over it... but by the time I sell it, you will have sold your xxxcr.
see you Sunday....
SteveJa is offline
Old 05-18-2007, 05:13 PM
hey, if you noticed, I'm the only one here trying to help you out
Old 05-18-2007, 05:35 PM
d4man's Avatar
Post your complete setup and I will try to help you as best as I can.
d4man is offline
Old 05-18-2007, 08:12 PM
brian cox's Avatar
Trader Rating: 89 (100%+)
are you running an oz of weight under the rear bulkhead as well as a 1/4 oz in each rear corner of the chassis? that makes a big difference on the cars rear traction.
brian cox is online now
Old 05-18-2007, 08:15 PM
SteveJa's Avatar
yes I am. I will post my setup soon... Brian are guys coming to Omaha this weekend?
Later
SteveJa is offline
Old 05-19-2007, 06:46 AM
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Start with the 2005 Worlds set up. Our track are like the ones you describe and that set up is very good.
johnnyboy is offline
Old 05-19-2007, 09:46 AM
brian cox's Avatar
steve- i'll be there, and I think Chad and 2 other guys from sioux city are coming.
Old 06-12-2007, 04:31 AM
JEracing's Avatar
Default B4 Setup Sheet
Here's the B4 setup sheet
File Type: pdf
JEracing is offline
Old 06-12-2007, 06:31 AM
d4man's Avatar
It's an empty setup sheet. I need to see your setup to be able to help you.
d4man is offline
Old 06-12-2007, 06:51 AM
Go to No. 1 pistons in the rear with 25 or 30 wt shock oil and green springs. I have to do it here b/c we have so many 1/8 and truggies running even the drilled No. 2's won't work. No limiters in the front shocks, and shocks unthreaded b/w 1 to 2 turns. If the rear is loose in, try adding some camber to the rear tires, I think I ended up running about 1.5 deg this weekend. How much antisquat are you running? Tires would beb the other thing to check, be sure you have the same tire/foam combo as the guys who are running well.
cjtamu is offline
Old 06-12-2007, 09:57 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Best place to post your question would be www.rc10b4.com in there b4 forum.
I would say start with the worlds setup, and go about 2.5 to 5W lighter in the rear.
I ran on a track similar in conditions, Worlds setup exactly as a starting point made the most difference. Especially the antisquat changes.
Also, Check your throttle control. Exactly when is the rear coming around on you?
As for tire setup, you may want to keep in mind that what may work for the Losi guys may not work for you on your B4.
Cain is offline
Old 06-12-2007, 10:08 AM
Default B4 setup
See what you have to do in this situation is follow the Associated guide to setting up your B4. Start with the worlds setup, basically the only setup to run. Put Team Losi Big Shots on the rear with stock foams. Now comes the tuning. If the rear is loose add weight. If the car pushes, add weight to the front. After these hard tuning sessins the car will be good. And that is how you setup a B4. Just make sure whatever you do, do NOT change your locations. If you do it will bring on the end of days. LOL
Naw, The worlds setup is a good place to begin. I would put silver springs on the rear. But the big shot is a great tire. The rounded carcass lets the car be more stable in rutts and bumps that big outdoor tracks produce. Play with ride height too.
Butters37 is offline
Old 06-12-2007, 10:36 AM
Tech Legend
Cain's Avatar
bigshot is an excellent tire.
If you find you are having more variances in the surface, you could also try a proline step-pin and use losi foams in them. I have tried this setup as well and when the track condition went from hardpacked but no fluff on top to fluffy or broken up, they came through the best.
As for the 1/4 weight on the rear sides, do you have a pic of this and does it apply to the T4 as well?
Cain is offline
