Old 06-13-2007, 09:33 AM   #1
Default Want to lower my stampede
I have a traxxas stampede XL-5, and I love thing. My only problem is it tends to flip over alot when I turn. I won't to lower the truck a little, either by buying adjustable shocks or just buying shorter springs. My problem is that Traxxas doesn't seem to make lowering springs or adjustable shocks for the stampede. Can someone tell me what will be compatible.
rcburner is offline   Reply With Quote
Old 06-13-2007, 09:47 AM   #2
teabag's Avatar
put some orings on your shock shafts under the piston. more orings, the lower it will be.
teabag is offline   Reply With Quote
Old 06-13-2007, 05:26 PM   #3
SocalSnakeEyes's Avatar
Send a message via MSN to SocalSnakeEyes
use losi or evader shocks depending on your cash flow. Try this:http://www.snakeeyesracing.freeservers.com/index.html
Curator of a large 90's Losi and Traxxas offroad heard. http://www.rctech.net/g/album/8613420#
"Speed only counts if you make the next turn"
R.I.P. SoCal Raceway 12-16-2007
SocalSnakeEyes is offline   Reply With Quote
Old 06-14-2007, 10:08 AM   #4
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Trick we did to get it to corner better was to mount the battery underneath the chassis. cornering was better.
Just keep in mind the vehicle is a monster truck, it does have those limitations.
Old 06-14-2007, 11:27 AM   #5
wfdfiremedic's Avatar
yeah, if you mount the battery underneath the chassis it will handle much better in the turns etc.
wfdfiremedic is offline   Reply With Quote
Old 06-14-2007, 08:27 PM   #6
Use rustler front shocks all the way around.
beanie is offline   Reply With Quote
Old 06-15-2007, 02:46 PM   #7
I thought about doing something like this, however wouldn't that make the back lower than the front? The way the stampede is stock - the back shocks are taller than the front shocks and the truck is level.
Old 06-15-2007, 03:34 PM   #8
There are ways to widen the Stampedes stance. I used RPM Losi LXT front arms but I have heard of people using the rear arms on the front, HPI Nitro Rush arms, and even Jato arms (too wide IMO unless you use a FLM long chassis)
You could just buy the FLM extended front arms (Probably the easiest and cheapest way to go)
This allows you to use Stampede front wheels all around.
LiveLarge44 is offline   Reply With Quote
Old 06-16-2007, 08:19 AM   #9
Alltapdout's Avatar
Fast lane machine towers and arms, you can lower your vehicle dramaticly
Alltapdout is offline   Reply With Quote
TRF 415 4mm LOWER DECK MelvinLee R/C Items: For Sale/Trade 2 03-07-2008 06:33 PM
TC5 with ITF lower deck olhipster1 R/C Items: For Sale/Trade 5 12-08-2007 12:15 AM
414 Lower Deck Nielonsx Australia Wanted to Buy 1 10-07-2006 07:05 AM
Lower torque better for RWD? Liko Electric On-Road 5 02-11-2005 03:43 PM
lower turn lower tourqe? kh15 Electric On-Road 8 09-11-2004 08:21 PM
