Old 06-11-2007, 08:43 PM   #1
xtremelimits285's Avatar
Send a message via MSN to xtremelimits285
Default Can i use my reedy pro charger to charge lipos?
Can i use my reedy pro charger to charge lipos, just for 6-10 charges, im getting a 4s 8000mah an a 2s 8000mah an will be out of money till the 1st of august,then ill buy a Thunder Power TP205 Lipo Balancer , an Thunder Power 1010C Charger , but till then can i use my reedy pro? i would only charge the packs up to 70-80% of there capacity for now and at like 3amps, i would also just run them down to 20-25%, and i will be sitting rite next to the lipos while they are chargeing.....
xtremelimits285 is offline   Reply With Quote
Old 06-11-2007, 08:49 PM   #2
foolio's Avatar
Sounds like you're pretty patient buying things as you get the money. What's waiting a couple more months to do it right? I am sure you still have the standard NiMH packs; why risk damaging your new lipos? On another note, I don't know if you want to be sitting next to those lipos if you are charging them with the wrong charger.
foolio is offline   Reply With Quote
Old 06-11-2007, 09:38 PM   #3
Trader Rating: 18 (100%+)
Don't do it. Plain and simple.
trilerian is offline   Reply With Quote
Old 06-11-2007, 09:51 PM   #4
sport10's Avatar
Don't do it!!!! Lipo's are highly intolerant to incorrect charging. You can damage your lipos or even worse start a fire!!!
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 06-12-2007, 04:15 PM   #5
AzBobby's Avatar
just like in the other thread everyone told you do not charge lipo's with a charger that is not for lipo batteries. DO NOT USE YOUR REEDY FOR THE LIPO'S. it is extremely dangerous and hazardous to do so.
AzBobby is offline   Reply With Quote
whats is a good charger to charge 4200mah batt & 1-3 lipos asc0989 Radio and Electronics 0 10-21-2007 10:15 PM
What settings do i use to charge a 2s an 4s lipos with aIntellipeak ICE charger?HELP! xtremelimits285 Electric Off-Road 0 06-15-2007 02:10 PM
AE #611 Reedy Quasar Pro Charger cannot charge 8 cells with more then 1.0 AMP? Solara Electric On-Road 11 08-10-2004 08:52 AM
charge time on a Reedy rated X matched NI-MH 6 cell Team Associated Electric Off-Road 2 08-17-2003 02:43 PM
