Old 06-06-2007, 04:47 PM   #1
Trader Rating: 27 (100%+)
Default Where can I find Rustler steel tranny gears?
Well turns out my 4.5R brushless setup is way to much power for a stock rustler tranny. So does anyone know where I can find steel transmission gears so I dont strip them out again?
platinumjason is offline   Reply With Quote
Old 06-06-2007, 05:09 PM   #2
Vato Loco's Avatar
Here! http://www.rc-monster.com/stampede.php
Vato Loco is offline   Reply With Quote
Old 06-06-2007, 05:12 PM   #3
Thank you!
Old 06-06-2007, 06:01 PM   #4
I think that for now you are limited to a steel diff gear. There are aluminum idler gears available but the new VXL Rustler will have all metal gears. I am looking forward to this release.
LiveLarge44 is offline   Reply With Quote
Old 06-09-2007, 08:29 AM   #5
So I ordered the aluminum idler gear but it says to not use the stock steel top drive gear with it and to swap out to a nylon one. So now the question is will I be stripping the top drive gear rather than the idler one now? Is there truly anyway to bullet proof these trannys?
Old 06-09-2007, 10:16 AM   #6
AzBobby's Avatar
Nope. the reason for not using an aluminum idler gear and the two steel gears, is that obviously steel is harder then alum and it will strip that gear even easier then plastic one. and it costs alot more im sure. plus that is a TON of motor for a rustler. best bet is to see if any of the gears are the same from a T4 or a Losi truck, their idler gears are truly a strong nylon where as the ruslter gears i would be willing to bet are actually a plastic and not as tough as the ones from AE or Losi. kinda sucks since you spent so much on your brushless that this is your new problem now, hiopefully you can find a way to make it more durable.
AzBobby is offline   Reply With Quote
Old 06-09-2007, 10:21 AM   #7
If you wait a few months the metal gears will be available from Traxxas. you don't have to change the top gear just be sure that you use a good quality lithium grease and coat these gears well. With a lot of use you would eventually start to sharpen the teeth on the aluminum idler gear which would lead to main diff gear failure. Lots of people run their trucks this way for months even years with no problems.
Personally I would leave things as they are and watch for the gears to be released from Traxxas.
Old 06-10-2007, 11:30 AM   #8
Yeah I saw traxxas had the vxl coming out, I just didnt want to have to do tranny rebuilds every 2 or 3 weeks inbetween while Im waiting for the traxxas ones to come out. Looks like thats what I will be doing though =\
Thanks for the help everyone.
Old 06-10-2007, 06:03 PM   #9
dallasv8's Avatar
Talking tranny
i have run the alloy idler and metal top gear for a few years now with 10 turn motors and have not had a problem.just grease it up good and it should last for ages.
the new traxxas transmission does look good but it is a pity they didnt add a metal motor mount to it.
RC10B4
FT RC10T4
Proline Pro 2 SCT
Piss on holden
dallasv8 is offline   Reply With Quote
Old 06-11-2007, 09:36 AM   #10
seth556's Avatar
Trader Rating: 42 (100%+)
Anybody know if the sun gears in the diff are steel as well? I keep stripping those which locks my diff and causes it to strip.
seth556 is offline   Reply With Quote
Old 08-12-2007, 07:05 PM   #11
I plan on getting the VXl when it comes out will I have similar problems with the stock transmission unless i change to the metal or aluminum gears now?
jpolston is offline   Reply With Quote
FS: 37t steel ring gears for fw-05 mrgsr R/C Items: For Sale/Trade 0 08-06-2005 11:59 PM
NEW source for E MAXX STEEL idler gears kvrc Monster Trucks 0 06-15-2005 05:18 PM
TiNi Steel Gears for LST rskiba Monster Trucks 4 02-14-2005 07:02 PM
mgt tranny gears slowmotors Monster Trucks 1 06-28-2004 11:08 AM
Steel Spur Gears kolorkraft R/C Items: For Sale/Trade 4 04-11-2003 07:47 AM
