Old 05-31-2007, 05:52 PM   #1
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Default Help!!! I keep frying speed controlers - its getting expensive.
Long story short.......
I have a new T4 with a Futuba controler and reciever, 19t Pro (komoto dragon) motor tuned by High Velocity.
I have already fried a Duratrax speed controler that handles down to 8 turns, 2 weeks ago. Today I just fried a New Novak Rooster that can handle down to 12 turns.
The gearing is exactly to what the T4 manual says to do.
The Duratrax lasted 6 batteries of use on the track and the Rooster lasted 2 batteries on the street in front of my house.
The batteries were not used back to back either and every thing had enough time to cool.
What gives???
OG RC 10T is offline   Reply With Quote
Old 05-31-2007, 06:39 PM   #2
action135's Avatar
what kind of batteries?
are you sure the ae manual didnt say suggestions?
Ashton Brewer
First Bank & Trust Murphysboro
Alpha R/c Raceway
action135 is offline   Reply With Quote
Old 05-31-2007, 06:45 PM   #3
Johnathan's Avatar
you might be gearing too high, or maybe something is wrong with the drivetrain, such as excessive drag.
try putting a smaller pinion gear on the motor, 2-4 teeth less.
and then inspect your truck. take the pinion gear off, and spin the wheels. they should roll freely. if there's a grinding, or if it doesnt stay spinning, than ther is something whrong with the drivetrain.
also, are you running 6 cells, or 7?
make sure the motor's in good condition too.
good luck!!!
Johnathan is offline   Reply With Quote
Old 05-31-2007, 07:17 PM   #4
OG RC 10T's Avatar
The only suggestions in the AE manual was the spur and pinion sizes which I did exactly what it suggested. The batteries are duratrax 4200 mAh nimh 6 cell pacs from Tower Hobbies.
The motor is new as well.
I also have a RC10T which is set up identicalrto the T4 that has a 10 turn double motor in it. I also run a CO 27 pro in that truck as well. The 10T was fully re done top to bottom and was completed just a couple of days after the T4 was built. They had identical electronics untill I replaced the first speed controler with the Novak. Except for the motors.
Is there any possibility that this motor can be causing them to fry?
I have not temped any thing with a thermometer, but none of the components seemed excessivly hot to the touch and though that isnt the correct way to do it, you can usually tell if something is way out of the norm.
Old 05-31-2007, 07:30 PM   #5
Johnathan's Avatar
i dont see why 2 speed controls would be fried with a 19 turn, but not with a 10 turn. it doesnt make sense.
just try a much smaller pinion, and make sure there is no drag.
and are you sure the esc's are frying? do they smell nasty? i cant smell through the internet, but i do know the burnt smell of silicon. it just doesnt smell good.
give us more info, and maybe we can fix this!
Old 05-31-2007, 07:36 PM   #6
The T4 manual recommends gears I never ever run. It recommends crazy big pinions. I think that gear chart was made when we ran NiCad batteries and much older tech motors that didn't turn any rpms.
The Komodo is a new motor that turns high rpms, which requires a smaller pinion, and 4200's have very high voltage, which requires a smaller pinion.
So gear way down from where you are the next time out.
If that doesn't work, theres something else wrong. Like a hub bearing is seized. Which is very common if you run in dusty conditions.
AE FT B44.2, SC10, T4, B4.2, B4, 18T, 18R, TC4, L3.5O ** Losi MRC Pro ** CRC Carpet Knife ** Axial XR10, AX10, SCX10 ** Traxxas EMaxx ** JR Z1
Manning is offline   Reply With Quote
Old 05-31-2007, 08:34 PM   #7
I kind of doubt it's gearing, or the motor would be getting way hot. I've never had a speedo give out before a motor.
I would run through the speed control setup very carefully. Make sure your trim and end points are properly set as the speed control suggests before going through the setup process.
Also, are you running a Shottky diode? I don't think the Rooster has one built in like some Novaks.
XXX-CR, XXX-T CR, XXX-SCT (Kertez conversion)
CRCRC.COM
Sneaky Pete Racing
Hammer Racing
Bike racer is offline   Reply With Quote
Old 05-31-2007, 09:27 PM   #8
I doubt it's the gearing. The AE gearing is a little high for my taste, but I generally only gear down one tooth on the pinion, even with mod motors. If the speedo ran fine with the other motor, then my bet's on the new motor. Is it an aluminum endbell? You could be shorting out.
Somebody mentioned the Shottky diode. Do those speedos have reverse? Don't run a Shottky with a reversing speedo.
cjtamu is offline   Reply With Quote
Old 05-31-2007, 09:31 PM   #9
glassdoctor's Avatar
Never use a Shottky diode with a reverse speed control! It will fry it very quickly.... ask me how I know, LOL!!
glassdoctor is offline   Reply With Quote
Old 05-31-2007, 10:45 PM   #10
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Your gearing is either to high or low. Also make sure you don't pinch any wires. And don't solder anything backwards.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 05-31-2007, 10:47 PM   #11
Dirt-Racer's Avatar
Send a message via MSN to Dirt-Racer
Gee, just out of curiousity. How do you know?
Dirt-Racer is offline   Reply With Quote
Old 05-31-2007, 11:20 PM   #12
Dougg's Avatar
OG??? Youre name wouldn't be Jrod, Would it?
"Inside joke in colo."
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 06-01-2007, 12:12 AM   #13
action135's Avatar
id have to go with gearing also. or for some crazy reason you dont have the speedo set up right.
Ashton Brewer
Alpha R/c Raceway
Old 06-01-2007, 07:25 AM   #14
OG RC 10T's Avatar
I havent used any of the diodes as per the instructions.
I know it dosnt make much sence? I mailed it back to Novak this morning and the other one to Duratrax last week. I will let you know what they say when I get either one of them back.
I will start temping everything to see what the Speed controler, motor and battery are running at.
Any ideas on what is a normal temp range for each of those?
Old 06-01-2007, 03:11 PM   #15
Alltapdout's Avatar
Sounds like a bad motor to me
Alltapdout is offline   Reply With Quote
Good Charger? Frying Batteries :-( LosiSuperTruck Electric On-Road 1 08-20-2005 11:48 AM
!!!!!!!!!!!For Sale!!!!!!!!!!! Speed Controlers OvalDaD R/C Items: For Sale/Trade 0 06-29-2005 06:40 AM
For Sale Lathe,Speed controlers and Brushless System OvalDaD R/C Items: For Sale/Trade 0 03-09-2005 05:32 PM
For Sale Lathe Speed Controlers OvalDaD R/C Items: For Sale/Trade 0 03-03-2005 05:45 PM
