Old 06-01-2007, 06:51 AM   #16
jono mad racer's Avatar
Send a message via MSN to jono mad racer
NOVAK 5.5!!!!!!!!!!!!!!!!!!!!!!!!
or
LMT 4200 with Uforce!!!!!!!!!!!!!!!!!!
Volkswagen Australia
jono mad racer is offline   Reply With Quote
Old 06-01-2007, 09:08 AM   #17
Tech Legend
Wild Cherry's Avatar
Originally Posted by wallyedmonds
i would not know this coz i cant get an x-11 and 007 speedo
ahh ok had to vent.
Thats hurting !!!
Trcr in Tacoma Washington has both in stock .....
253-565-1935
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-01-2007, 09:14 AM   #18
Novak with 7.5
Pull_My_Finger is offline   Reply With Quote
Old 06-01-2007, 09:20 PM   #19
wallyedmonds's Avatar
Originally Posted by Wild Cherry
Thats hurting !!!
253-565-1935
oh ok ill have a look see.
wallyedmonds is offline   Reply With Quote
Old 06-01-2007, 10:44 PM   #20
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
have run novak ss 5800, gtb 6.5 and mamba max 4600/5700 and would go with the mamba it is so programmable and also the most versatile speed control out there nothing against novak I love my 6.5 but the max has lipo cutoff punch control ect. Also you have a huge selection of sensorless motors to choose from.
cmain is offline   Reply With Quote
Old 07-16-2007, 08:31 AM   #21
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Anyone got picks of how they mounted there gtb's or mamba max's in there B4s?
Looking into one of these ESC's, had the mamba previously and it did well, just with it did 6V bec, but the price is still significantly better than novak.
Of the mamba motors, which is popular for the B4? 4600 or 5700? Had the 5700 in my T4 and liked it by the way.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 07-16-2007, 08:59 AM   #22
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 07-16-2007, 10:51 AM   #23
Tech Legend
Cain's Avatar
if you run the fan, do you need to cut a whole in your body?
Similar question on the MM units, any holes needed for the heat sinks? Also, what direction are you guys mounting the units so you can still access the USB Ports?
Old 07-16-2007, 10:53 AM   #24
msm
Thats a nice Setup ApexSpeed!!!
Would be great if you can tell me your setup, i see you got Orion Lipo batteries (4800), (which cutt of voltage do you use?)
Which Novak Brushlesss do you have and gearing? And i also like the battery tray setup where did you buy it??
Sorry for the questions..
Thanks!!
msm is offline   Reply With Quote
Old 07-16-2007, 11:17 AM   #25
squarehead's Avatar
I never ran a fan with mine, but I never ran a motor hotter than a 6.5 (which you shouldn't need in any 2wd car). Novak agreed that a fan wasn't necessary, especially with airflow over the ESC. I never had an issue with heat, indoors or outdoors. I also used a JConcepts Illusion w/scoop to make sure that there was cool air flowing over the heatsinks.
Thanks. I didn't use a voltage cutoff on that car. IMO, you don't need it if you don't try to squeak every second out of your packs. I own a Novak cutoff add-on, but never took it out of the bag. I've never found a need for them if you use your head and stop the instant the car begins to slow. Honestly, I've never taken a LiPo Platinum down low enough to even feel power drop-off.
The GTB system in the car is a 6.5 with a sintered rotor. I can't remember exactly, but it was geared in the range of 81/18, give or take one tooth up or down on the pinion. Way more motor than you can use most of the time—VERY fast.
The battery strap is Associated Factory Team carbon strap (#9586) with Associated Factory Team thumb screws (#1787).
HTH,
doug
Everything depends.
Nothing is always.
Old 07-16-2007, 11:23 AM   #26
msm
Thats great!! Thanks so much!!
Old 07-16-2007, 01:05 PM   #27
cfwdude's Avatar
I've been running a Novak 5.5 in my B4 for over a year now.
It's definitely a lot of motor, and takes a ton of throttle control, but it is manageable.
I just put in a 7.5 (after all this time of being told I was waay overpowered), i finally buckled.
It's much easier to drive, but I don't have that 'punch' that was always there when I needed it.
The 7.5 is enough motor, but I like having the extra power on tap with the 5.5
I don't use a fan, and get 23 minutes on some old IB4200's on the track.
cfwdude is offline   Reply With Quote
Old 07-16-2007, 03:02 PM   #28
fatbear's Avatar
Send a message via Yahoo to fatbear
If you were running on very slippery tracks like we do here in New Zealand would you use a bonded rotor instead of a sintered rotor to tame the maotor slightly?
fatbear is offline   Reply With Quote
Old 07-16-2007, 03:07 PM   #29
squarehead's Avatar
I wouldn't use the bonded rotor anywhere, personally.
The power does NOT change in the motor when you upgrade to a sintered rotor. It increases the brakes, and allows it to run cooler, so you can gear up (if you wish). The bonded rotors that I took out of my motors were dropped into the trash. I see no reason to swap between the two.
Everything depends.
Nothing is always.
Old 07-16-2007, 06:02 PM   #30
ManicRC's Avatar
Trader Rating: 135 (100%+)
I run at SoCal and find I can't put more power to the ground than the Novak 7.5 can dish out.
ManicRC is offline   Reply With Quote
Brushless Motor Failures and Motor Coolers or8ital Electric On-Road 54 10-03-2008 01:11 PM
Wanted : Novak 4300 brushless motor and a 13.5 motor lbckevin R/C Items: Wanted to Buy 6 09-18-2008 04:51 PM
For Trade: CC 6900kV Motor for another brushless motor Mooshu Beef R/C Items: For Sale/Trade 3 07-08-2008 01:56 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 02:17 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
