Old 05-30-2007, 03:43 PM   #1
Default Duratrax Maximum ST
so i got a duratrax maximum st a few years back and it hasnt been ran for atleast quite some time. today i tried to get it running but cant get it start. im using fresh fuel and a new plug. glow starter is good and the plug glows red hot.
i did notice that the flywheel turns extremely easy and i can turn it both ways. is that normal? i can see the piston moving up and down when the plug is removed. any ideas?
Tfizzle is offline   Reply With Quote
Old 05-31-2007, 08:34 AM   #2
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
if it has a pull start you not going to move the fly wheel both way.... how much fuel has it had? dose it have weak compression? dose it have a small hole in the fuel line?
MADMAN23 is offline   Reply With Quote
Old 05-31-2007, 12:21 PM   #3
the pull start is broken so its off. ive been trying to start it with a cordless drill. when i rotate the flywheel, i can feel it get tighter at the top but it doesnt seem as tight as it used to be. the flywheel seems to turn really easy.
im unsure as to what you mean about "how much fuel has it had.'' if you mean has the engine been broken in, yes it has. and it has had many tanks ran through after that. if you mean how much is it getting now, i got gas in the line to the carb and i primed it a few times.
if the engine is shot, what is a good replacement? just go with the same one? rebuild the current with new parts? i read once that O.S. engines fit this truck. dont know which one or if that was even true.
Old 05-31-2007, 12:27 PM   #4
forgot to answer the other question. i dont see any small holes in the fuel lines. will get some replacements though to make sure.
Old 05-31-2007, 12:55 PM   #5
got it to fire. turns out that the heat sink wasnt screwed down completely tight and i was losing compression.
Duratrax maximum bx nitrodude1 R/C Items: Wanted to Buy 0 05-26-2007 12:42 AM
Duratrax maximum st creamsodauk R/C Items: For Sale/Trade 0 11-15-2006 04:09 PM
Duratrax Maximum MT Pro 86Lude20Si Electric Off-Road 0 03-29-2006 05:37 AM
Duratrax Maximum MT RTR coolkide R/C Items: For Sale/Trade 0 12-29-2004 02:46 AM
Duratrax Maximum ST skittaboo Electric Off-Road 6 05-13-2003 09:19 AM
