Old 05-30-2007, 02:43 AM   #1
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
Default B4 LiPo?
What pack is everyone running? What balancer is preferred?
Alan
racer34v is offline   Reply With Quote
Old 05-30-2007, 03:08 AM   #2
Trader Rating: 6 (88%+)
I run both a 3s or a 2s Maxamps 4000mah lipo battery in my B4. I use this: http://www.maxamps.com/proddetail.php?prod=LBA10
balancer
and this: http://www.gravesrc.com/GPMM3153_GRE...p/gpmm3153.htm
charger.
steve671 is offline   Reply With Quote
Old 05-30-2007, 08:15 AM   #3
I have run several of the 7.4 volt packs. Any of them will work but so far I like the orion 4800 or the maxamps 6000. There is a trackpower pack that looks good.
nichocgn is offline   Reply With Quote
Old 05-30-2007, 09:14 AM   #4
I'm running a Thunder Power 8000 2s pack in my B4. I've had maxamps 6000 2s, a polyquest 2500 2s, and a Kokam 3200 3s in it before and they all worked great. It didn't handle very well with the 2500(5.5 oz) though, too light.
scoob is offline   Reply With Quote
Old 05-30-2007, 11:42 AM   #5
racer34v's Avatar
great! thanks for the info, i just ordered an orion 4800, it appears if it rarely needs a balance (after 100's of normal cycles i am told) and you can do so manually if needed.
Old 05-30-2007, 12:55 PM   #6
Trader Rating: 26 (96%+)
The 8k mah packs are probly your best bet.
party_wagon is offline   Reply With Quote
Old 05-30-2007, 12:56 PM   #7
I'm running the Peak equivalent of this in my B4 and absolutely love it! I weighted the pack to the equivalent of a 3300 NiMh (to about 13 ounces total if I remember correctly) so I could feel more confident using various setups. I found lead tape and covered the entire bottom and most of the sides of the battery. It has to be very thin though.
glitchy is offline   Reply With Quote
Old 05-30-2007, 07:53 PM   #8
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
A B4SL we just painted for a customer, not sure if he is using a LiPo though!
...Jim
W.E.D.
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 05-30-2007, 08:36 PM   #9
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Well I'm not trying to crash the party with a Losi but if you can see them there are weights on the battery holder. I'm running the Max Amps 6000's totally awesome packs by the way.
The weights can be purchased from Xray its there sedan weights they work great, they also come with round ones that can be fit on the nose to keep the front end on the ground. I can put up a close up if you like?
And the Orion 4800's fit perfect to.
I servo taped the weights and then zip tied them. They fit like they where made for it. And I will add the extra weight helps a lot when running lipo.
Let me know if you guys want a closer shot?
Now I just need a paint job like the one above. Very talented.
UN4RACING is offline   Reply With Quote
Old 05-31-2007, 09:32 AM   #10
I considered putting the weights on the strap too, but decided to put as much as possible on the underside of the battery to have the lowest center of gravity possible...in some ways this way could be better than running NiMH cells as there's a bunch of weight right at the chassis. On the strap you're what about 3/4 to an inch higher?
Old 05-31-2007, 11:22 AM   #11
Tech Legend
Wild Cherry's Avatar
My B-4 with ballast installed....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
NIP Novak 5amp lipo regulator with volt monitor, NIP venom 1600mah lipo rx pack sharkman R/C Items: For Sale/Trade 1 06-10-2008 02:36 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
FS TrakPower 7.4V 4900MAH Hardshell Lipo,TrakPowerBalancer,TrinityReference 4500 Lipo ffpm46 R/C Items: For Sale/Trade 11 01-29-2008 06:11 PM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
