Old 05-29-2007, 02:25 PM   #1
scoobydo's Avatar
Default Titanium Screws in Alum for Offroad
I hear that Titanium Screws into Aluminum tend to bind.
I have heard people using a tiny amount of grease or threadlock.
The grease I understand, but if your having problems with the screws binding to the aluminum, wouldn't the threadlock make it worse?
Or, does it create a barrior between the two that doesn't allow it to bind?
I'm finally going to replace my 501X screws which have been sitting around forever.
scoobydo is offline   Reply With Quote
Old 05-29-2007, 02:30 PM   #2
oople's Avatar
I can't say I noticed it bud. I have replaced all the (nasty) screws on my 501X with cheap Ti screws, the heads are so much better than the kit ones anyway that there have been no problems.
Jimmy Storey - www.oople.com
oople is offline   Reply With Quote
Old 05-29-2007, 02:37 PM   #3
Davidka's Avatar
Trader Rating: 77 (100%+)
Thread lock actually works just like grease for this purpose, just not slippery. It insulates between the two types of metal and seals out ant contaminants. Use locktite blue and you will be able to get these screws out down the road. If you don't you will experience titanium "galling" where a tiny bit of bionic corrosion forms and the two pieces of metal will be together forever. This was a common problem with Titanium bicycles. Water bottle screws, bottom bracket threads and seat posts would all get stuck, usually permanently. This all ended when we began using anti sieze compound.
Old 05-29-2007, 02:38 PM   #4
scoobydo's Avatar
So your not using anything?
Old 05-29-2007, 04:31 PM   #5
RBMike's Avatar
I've run ty screws in my last 3 Mugens with no issues. The only place I don't use them is on the chassis braces because they tend to break there. Ty screws can save you a whole lot of weight if you use enough of them but they are more brittle. My rule is to replace as many srews as you can with ty then if one breaks put a steel one back in that (strees prone) location. The only problem I ever had with "galling" was strangly on the ty hinge pins in the A-arms (plastic). I'm still not sure I understand why that happened (every time).
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Titanium screws where to buy? olhipster1 Electric On-Road 8 09-07-2007 06:51 AM
3mm Titanium Screws? JeffEmbracedDC Nitro Off-Road 3 08-05-2007 11:23 AM
Titanium screws / Aluminum screws ? rcnewb2004 Electric On-Road 26 05-22-2006 09:45 AM
Titanium screws drx Electric On-Road 14 01-27-2005 08:09 PM
Titanium screws Fangio Electric On-Road 6 04-09-2002 08:27 AM
