Old 05-28-2007, 11:54 AM   #1
streetracer745's Avatar
Send a message via AIM to streetracer745
Default LRP sphere ESC help?
i have a LRP Sphere Comp ESC with a reedy neo-one motor in my buggy. its done great for over a year, but the other day it just quit working. the servo works, but the motor doesnt. what is the problem with this and what should i do to fix it? thanks in advance
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 05-28-2007, 12:18 PM   #2
Tech Legend
Wild Cherry's Avatar
First, try another motor that you know performs correctly...
If the new motor run`s , its your old motor that is bad ...
If the new motor don`t run , its your ESC that is bad......
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-28-2007, 12:48 PM   #3
AzBobby's Avatar
you could do as cherry suggested. also the servo will work since it is not run through your esc in any way just battery power goes from it the the reciever so then your servo will work. another fix for your lrp is to buy a novak and never worry about it.
GO TECH
AzBobby is offline   Reply With Quote
Old 05-28-2007, 01:33 PM   #4
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Same thing happened to mine...and lots of others (stopped after 8months to a year). I just got them fixed for like $30 or so at A/E.
I would rather do that than have all the clutter of the Novak. My Comp is working great again and I like the way it works WAY better than the GTB I used while the LRP was away. The new 2007 Comps have solved any problems and are champ!
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 05-28-2007, 01:49 PM   #5
well just checked, and its the ESC. so i guess i will send it in to AE. will they fix it or send me a new one? i would rather have the 07 version than the older version, but dont want to buy one, and if im going to end up with having to buy a new system, im going to get a faster one. i dont like novak. ive had nothing but bad luck with them and dont plan on taking a chance of loosing $250 on a system that will fry
Old 05-28-2007, 02:09 PM   #6
Tech Legend
Street racer ,
Lrp shipments only come in every couple months ...
That means you may have a small wait , but they most likely will return to you a new ESC...
Send it in a soon as you can....
The Lrp is very popular and in high demand....
So don`t delay.....
George W. Cherry
Old 05-28-2007, 02:37 PM   #7
well i was planning on packing it up and sending it in tomorrow
but then i hooked it up again to just double check and possibly save a little cash, and it worked..... not sure why. i plugged it in just like before and havent changed anything. its kind of weird, but im not complaining cause ti works fine again.
Old 05-28-2007, 11:03 PM   #8
SWTour's Avatar
I had one that when you pulled the trigger the motor looked like it was bound up... it would try to spin, then try to spin backward, but moved less than 1/4 inch.
Turned out it was the sensor wires where they plug into the ESC, the plug had come slightly loose.
SWTour is offline   Reply With Quote
Old 05-28-2007, 11:07 PM   #9
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Service
be ready to wait a while if you send it in for service..
if you're really lucky...3 weeks...
if you're not ....3 months...or longer.
olhipster1 is offline   Reply With Quote
Old 05-29-2007, 11:38 AM   #10
SWTour, thats exactly how mine was. so im probably going to get a new wire. i want a shorter one anyways
Old 06-21-2007, 02:04 AM   #11
Eggyolkeo's Avatar
Did you say 8 months? That's exactly when mine started playing up.
Mine started thermalling, but wasn't hot. It was like 2 laps into it then would stop. Leave for a minute then it was ok again. I tried replacing the sensor wire, no help.
Sent it in (thanks lifetime warranty) and STILL WAITING 5 weeks later. It's a joke. I'm apparently getting a new replacement, but I've now missed 2 meetings and valuable points, so not happy.
I agree with the size thing though, but will probably go a different brand next time as this has left a sour taste.
Eggyolkeo is offline   Reply With Quote
Old 06-21-2007, 11:11 AM   #12
mine works fine now. i just reprogrammed it and it works great
LRP Sphere TC ESC Rockin Johny R/C Items: For Sale/Trade 3 07-23-2008 08:40 PM
LRP Sphere, Sphere 2007 or TC NT Australia Wanted to Buy 1 06-08-2008 04:39 AM
Sphere vs GTB tarheelquality Radio and Electronics 6 01-09-2008 09:14 AM
Different Between LRP sphere and the LRP sphere TC SPEC [email protected] Electric On-Road 3 09-29-2007 04:09 PM
Sphere Comp and Sphere TC Differences Paul_67 Electric On-Road 4 08-20-2007 03:27 PM
