Old 05-27-2007, 10:12 PM   #1
Trader Rating: 42 (100%+)
Default NITRO .21 ENGINE BREAK IN PROBLEM
WAS BREAKING IN A NEW ENGINE. HEAT CYCLING, NOT ABOVE 210 NOT UNDER 180. TANK 4 ,5 AND 6 ENGINE HAS A TIGHT FEEL WHEN DONE WITH 10 MIN RUN AND YOU PUT PISTON AT BDC. THEN AFTER 5 MIN ITS FREE FEELING AGAIN. THEN THE NEXT RUN 10 MIN IN TO THE RUN MOTOR IS 209 OR SO AND YOU CAN HEAR THE MOTOR PULLING ON A LOAD, AGAIN IT FEELS TIGHT. THEN IT COOLS ITS FREE AGAIN. I HAVE NEVER NOTICED THIS ON ANY OTHER ENGINE I HAVE BROKE IN, AND HAVE DONE 6 MOTORS OR SO ANY HELP APPRECIATED.
KEITH is offline   Reply With Quote
Old 05-28-2007, 06:55 AM   #2
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
1 motor did the same thing as you are saying.... it was a xtm motor... it got so tight it got stuck and stalled the motor.. i have to take it apart to get it free... for me it started to get more free at 7-10 tank's....
MADMAN23 is offline   Reply With Quote
Old 05-28-2007, 07:41 AM   #3
HOW DID THE MOTOR RUN THEN GOOOD? AFTER THE 11 OR 12 TANK THANKS FOR REPLY
Old 05-28-2007, 08:08 AM   #4
MADMAN23's Avatar
it ran good....
Old 05-28-2007, 12:15 PM   #5
schmelme's Avatar
What motor is it? Take the back plate of and check to see if the rod is rubbing the back plate i have seen this happen sometimes on a hot motor.
schmelme is offline   Reply With Quote
Old 05-28-2007, 09:44 PM   #6
changed the front bearing and it was fixed
Nitro Engine Break In d4_racer Australian Racing 50 02-22-2011 03:42 PM
Hudy Nitro engine break in bench cwalters R/C Items: Wanted to Buy 1 09-21-2007 01:07 PM
Nitro engine break in steps. Phoenix82 Rookie Zone 1 05-16-2007 10:47 PM
nitro engine break in stand TNT racing R/C Items: Wanted to Buy 0 08-22-2006 08:08 PM
Nitro Engine Break-in stand rodneybarrett R/C Items: Wanted to Buy 0 01-21-2004 09:48 PM
