Old 05-27-2007, 07:44 PM   #1
rregl0612's Avatar
Trader Rating: 33 (100%+)
Default Lipo Charger questions
I just have a few questions about Lipo..
First are there any good reads to learn about the batteries themselves.
secondly what is a good charger for these.. something dependable.. up to 150$
and thirdly.. Is it worth it..???
rregl0612 is offline   Reply With Quote
Old 05-27-2007, 07:49 PM   #2
wallyedmonds's Avatar
well im using the orion 3200 lipos and the orion charger
i charge them at 3.2A like the book said and its a lot better than sub c cells.
wallyedmonds is offline   Reply With Quote
Old 05-27-2007, 07:56 PM   #3
XrayMichaelT2's Avatar
Send a message via AIM to XrayMichaelT2
Here are my guidlines
-Always charge at 1c (ex. 3200 Li-Po charge 3.2amps or 4800 charge at 4.8amps)
-whenever you feel your battery start to loose any power, pull it off teh track and cahrge it soon as possible(this should be around 6 volts.) You can buy a Li-Po cutoff.
-always use a Li-Po charger, The best all-around charger is the Duratrax ICE
Michael
XrayT2
Ft. B4
Ft. T4
XX-4
Promarch 4200's, Orion carbon 3200
Duratrax ICE
Novak GTB 13.5
www.Michianarc.com
www.embassyraceway.com
XrayMichaelT2 is offline   Reply With Quote
Old 05-27-2007, 08:29 PM   #4
Trader Rating: 26 (96%+)
The best lipo charger is the astro flight 109. The ice is a good all around charger if you are still going to use nimh cells and such, but the astro flight is the best lipo charger. The astro flight will peak the cells w/ a little more juice and do it faster then the ice will peak the cells. Typically the chargers will peak the cells at 8.4 volts and the 7.4 volts is the nominal voltage of the packs. All of the chargers will peak the packs to 90% charged at a 1c rate, and then they will slow way down for the final 10% of the charge. I guess the simple way to put it, it will take 50 minutes to 90% peak a dead pack and another 30 minutes to deliver that last 10%. The packs are worth the investment.
party_wagon is offline   Reply With Quote
Old 05-27-2007, 09:13 PM   #5
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
[QUOTE=rregl0612]I just have a few questions about Lipo..
First are there any good reads to learn about the batteries themselves.QUOTE]
Here's a few I found.
http://www.helitown.com/LipoBattery.html
http://rclovers.com/GetTheMostFromLipo.htm
Hi my name is Mike, and I'm a Chromeholic, my wheels have been chrome free for over a year, thanks to everyone who made fun of them.
*Chrominator* is offline   Reply With Quote
Old 05-27-2007, 09:15 PM   #6
Old 05-27-2007, 11:34 PM   #7
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Try this?
http://www.kokam.com/english/product/kokam_app_01.html
I use the Ice charger.
And its more than well worth it.
UN4RACING is offline   Reply With Quote
Old 06-11-2007, 07:59 PM   #8
rregl0612's Avatar
okay so what does the balancer do.. and will I need one.. I will be powering a mamba 5700 in a Dark impact..
I was looking between 4400 and 5500 mah.. and 2s1p lipos..
Thanks bubyes
Old 06-11-2007, 09:56 PM   #9
sport10's Avatar
The balancer just keeps the cells in the pack at close to the same voltage. This way there is less risk of overcharging one of the cells in the pack when charging the pack. Performance wise you will not be able to see the difference.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 06-11-2007, 11:20 PM   #10
action135's Avatar
is there a difference between lithium ploymer, lithium ion, and lithium manganese? besides the obvious chemical makeups.
action135 is offline   Reply With Quote
Lipo Battery/Charger Questions jaminit Rookie Zone 8 09-09-2008 01:23 AM
Lipo charging/charger questions...... jb7778 Electric Off-Road 29 03-15-2008 06:02 AM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
NEW LiPo Prototype Battery Charger Questions. ICT-POWER.COM Electric On-Road 18 08-25-2005 02:46 PM
