Old 05-28-2007, 07:50 PM   #16
GymBeam's Avatar
taminya dark impact. there is your problem
GymBeam is offline   Reply With Quote
Old 05-28-2007, 07:55 PM   #17
streetracer745's Avatar
Send a message via AIM to streetracer745
its not for racing. but i do run at the track. im making a 1/10 electric truggy out of it right now, and want to make it faster. i think i am going to end up wit ha mamba max 6900
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 05-28-2007, 10:05 PM   #18
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
PULL THE TRIGGER ALL THE WAY!!!!!!!!
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 05-28-2007, 10:48 PM   #19
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Just remember they faster you go the more broken parts.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 05-28-2007, 11:00 PM   #20
jk racing's Avatar
Trader Rating: 20 (100%+)
Originally Posted by streetracer745
what about deans plugs? do they really give a little extra boost?
The answer to that could be yes, if you are using the stock Tamiya plugs, then yes, the Dean plugs will be better for you. The tamiya plugs generate heat and have poor connection. The Deans will solve those problems.
Find a gearing chart for the cars you are racing against & your car. Compare the final drive # and get as close to that as possible. Then, if all things are comparable, you should be about as fast as they are.
There are upgrades needed if you want the car to be competitive on the track, better shocks, a slipper set up (I believe there is a conversion kit to use the AE spur gears & slipper), tie rods...and other little bits and pieces. Make sure you are running the same tires as "the fast guys". Tires are everything on the track, off on tire selection, off on everything else. You have to plant the power your car has.
--Joey--
Venom Batteries & Chargers
Old School Racer & Vintage RC Car nut
jk racing is offline   Reply With Quote
Old 05-29-2007, 11:37 AM   #21
ok ill get deans. and i have good tires and suspension. no slipper yet, but will soon be getting one
Old 05-29-2007, 11:51 AM   #22
speedsterblade's Avatar
besides motor, gearing, esc, batts... tires!!!! are a biggest factor. after you get that straigth, I'd buy some Ti turnbuckle/hinge pins. I polish all my hinge pins for smoother action. Also the stock shafts. You want the suspensions as free moving as possible. Then I'd start buying all the lightened parts you can find. Those mods are usually not cheap for the amount of weight you same but they will start adding up and will give you a quicker car. I haven't spent the money for any ceramic bearings yet....I just relube them all w/ light oil..including all the diff/tranny bearings.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Speed Secrets (SS) RedEnzo Malaysian R/C Racers 197 09-21-2013 06:23 AM
LRP SPHERE TC VS. SPEED PASSION GT LPF V1.1 your thoughts? one*eighteen Electric On-Road 16 05-02-2009 01:38 PM
Secrets to RC B4 Racer1 Electric Off-Road 139 02-05-2009 11:42 AM
my losi speed t offroad thoughts NightWolf Electric Off-Road 7 07-24-2008 02:18 AM
Racing Secrets!! Steve Charles Electric On-Road 68 11-22-2003 09:47 AM
