Old 05-24-2007, 05:29 PM   #1
USATorque55's Avatar
Default XXX-NT AD1 Modifications
There doesn't seem to be that much information on this truck anywhere.
What would you guys recommend in terms of setup, gearing, hop-ups?
Is it worth it to put it to AD2 status if I'm not racing?
Thanks,
Torque
USATorque55 is offline   Reply With Quote
Old 05-24-2007, 06:10 PM   #2
gubbs3's Avatar
The only thing I would suggest is using the AD2 rear pivot block. It's much more durable and has 4 degrees of toe in rather than 3. Helps a lot to keep the truck straight under power. Other than that, its really not worth a complete conversion to AD2. For that you need new arms, hubs, drive shafts, shock tower, front arms, spindles, caster blocks, and axles. Then you need all new wheels as well. It's a lot of money and any performance benefit is nominal. Both versions can be set up to the standard "Dirt" setup which I rarely stray from so any other options aren't really needed.
gubbs3 is offline   Reply With Quote
Old 05-24-2007, 06:54 PM   #3
Can I use the stock rear a-arms with the new bulkhead?
Old 05-30-2007, 02:33 PM   #4
kevinmajor's Avatar
The rear bulkheads are interchangable. The only difference is the amount of toe in and the ad2 has the center support to make it stronger.
kevinmajor is offline   Reply With Quote
Old 05-31-2007, 12:13 AM   #5
Trader Rating: 26 (96%+)
The only other thing you may want to do is replace the rear shock tower with the plastic rtr one and replace the ball cups on the rear turnbuckles w/ mugen captured ends. The rear pivot is a weakness as well. The softer shock tower will help to absorb blows when the truck takes uneven landings.
party_wagon is offline   Reply With Quote
FS-New E-maxx RTR w/Modifications $300 NitrousVR6 R/C Items: For Sale/Trade 3 01-22-2007 03:18 PM
Engine Modifications Blazin~ Nitro On-Road 23 01-15-2007 01:29 AM
Trinity DPD Modifications? MManson Electric On-Road 16 12-15-2006 01:44 AM
Engine Modifications jamiekulhanek Rookie Zone 15 09-11-2004 11:28 AM
Charger Modifications ctardi Electric Off-Road 13 06-22-2004 09:06 PM
