Old 05-24-2007, 07:38 AM   #1
Default Mamba ESC Throttle delay?
I've setup the ESC fine, however the response before the motor starts turning and the throttle finger is quite high, I've never seen an ESC with such a delay before the throttle starts to move. It's as if it's offset.
I have to move the throttle a good 4-5 mm before it starts moving. After that it's fine. I can correct this by trims and subtrim however I am just curious if others noticed this too?
I've tried 2 radios and I've tried brushed/brushless mode. Can anyone tell me how their mamba works and if they also have some throttle offset before it kicks in. Thanks.
entilza is offline   Reply With Quote
Old 05-24-2007, 07:39 AM   #2
This is a Mamba Max, btw. thx.
Old 05-24-2007, 08:51 AM   #3
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
You need to reset your esc to your radio.
I had this issue as well with my DX2. I reset the radio, and also up-d the timing or punch control on the speedo as well. instant takeoffs now.
really powerful unit.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 05-24-2007, 04:05 PM   #4
Hi thanks, I have reset the mamba numerous times, on both radios..
When you pull the throttle do you immediately hear the frequency of the mamba kicking in or do you have to move it 4 mm before you hear the sound and then the motor starts turning?
My concern is with the distance the trigger sends a signal and the esc starts moving. I've never had an ESC with such a far distant response. I have a 3PK which I use on multiple cars fine. I've reset the model and everything yet this mamba is still 4 mm before it starts moving
Old 05-24-2007, 04:33 PM   #5
Trader Rating: 35 (100%+)
I noticed this too when I used the mamba max systems. I let other people drive my buggy, and each and every one of them thought the throttle felt 'laggy'. I didn't notice this in brushed mode, only brushless mode. I would hear a bit of a squealing and then all of the sudden, the thing would take off. I hated this about the mamba actually, it just felt very inconsistent because of this lag, and then the sudden power. It would make the buggy spin out. This lag is also noticeable coming out of turns.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 05-24-2007, 05:43 PM   #6
Tech Legend
Cain's Avatar
Not having this issue anymore. You need to up the power ranges.
Old 05-24-2007, 06:25 PM   #7
Like Cain mentioned, if your radio has "punch", use it. I use it on everything.
AE FT B44.2, SC10, T4, B4.2, B4, 18T, 18R, TC4, L3.5O ** Losi MRC Pro ** CRC Carpet Knife ** Axial XR10, AX10, SCX10 ** Traxxas EMaxx ** JR Z1
Manning is offline   Reply With Quote
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 06:19 PM
Server Load Center Issue May Cause Delay Of PM's DogboneS R/C Items: For Sale/Trade 0 12-15-2007 06:36 AM
Throttle Delay??? trumpster1 Nitro On-Road 13 07-16-2007 07:48 AM
Cyclone S UK delay academygaz Electric On-Road 5 09-04-2006 02:38 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 10:59 AM
