Old 05-23-2007, 12:01 AM   #1
MadRacer's Avatar
Trader Rating: 33 (100%+)
Default 10 Pipes.
Has any one played with different tune pipes for off road stadiums??
Seems to be common with the 8 th scalers but is worth while with the Stadiums or is the stock pipe that good you can't improve on it .. Thanks..
Boondal vintage Tamiya's
https://www.youtube.com/watch?v=vtmCddStNyM
QLD State Titles winner in 6S EB CAT
MadRacer is offline   Reply With Quote
Old 05-23-2007, 01:37 AM   #2
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I havent played with pipes in my 10th scale ST....but it really is something that should be checked out I think, as fuel economy, speed and torque can be improved and suited to the track and engine more.... The problem is that I see with my AD2 is mounting anything beside the drake pipe. (Yes I know its an easy fix with wire and fuel tubing, but I REALLY dont like the XXX-NT sport method of securing the pipe.)
Besides, my little OS .12 CV-R suits me just fine with the Drake pipe. If I want less torque, I move up in CB teeth and/ or play with the slipper clutch.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 05-23-2007, 07:29 AM   #3
kevinmajor's Avatar
I am also running a losi AD2 with an OS CVR and stock AD2 pipe. It has excellent torque and a smooth top end, so I have no reason to change it.
kevinmajor is offline   Reply With Quote
Old 05-23-2007, 09:04 AM   #4
The best thing I have found is to use one pipe and several different length headers for 10th scale stadium trucks. My son runs an AD2 and I have 6 different length headrs we use to tune the powerband of the motor. A shorter header give more low end and a longer header moves the power band to the high end.
Tekno RC, Alpha Plus Engines
AKA Products, Lutz RC, A-Main Hobbies
NitroPro Fuel, Hot Headz Engine Heaters
Raceform Bodies.....Reilly Paint (Just Plain Wicked)
gasser is offline   Reply With Quote
Old 05-23-2007, 09:42 AM   #5
Actually a longer header gives more low end, and a shorter header gives more top speed.
Old 05-23-2007, 11:39 AM   #6
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
correct!!!!!when i was running my ae gt, i had 6 different headers (short to long) for tuning, and it worked very well....
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 05-23-2007, 12:06 PM   #7
If one is using a 2 piece manifold and header joined by the a rubber/silicone coupler, you can "tune" header length by moving the pipe farther or closer to/from the header. I have a side exaust pipe and the AD2 pipe, so this makes more sense and is easier for me that swapping headers.
Old 05-23-2007, 01:17 PM   #8
gubbs3's Avatar
I have only tried a few but what would you really need more power for anyway? That's one reason so many pipes are availible for 1/8 because you CAN use the power. In 1/10 we all have so much power that the right pipe is the one that drives the smoothest. The drake pipe is great, I run it and have no reason to change, the new AE "smoothie" pipe is awesome as well.
gubbs3 is offline   Reply With Quote
Old 05-23-2007, 03:23 PM   #9
pumpkinfish's Avatar
I have run the Drake pipe, AE torque, AE RPM and AE smoothy all on the same vehicle. For snappiness, I like the Drake or AE RPM. For overall economy and smoothness, the AE Smoothy is the best. I felt so slow with it I hated it at first. After a few races, I realized it calmed down my Trinity Drake Platinum that it made me faster. The engine felt a little more linear also.
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 05-23-2007, 09:01 PM   #10
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
anyone has any experience using a Paris turbo ribbed pipe or a RB X12 pipe on a 2wd gas truck? please share any info if there's any available, thanks.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 05-23-2007, 09:15 PM   #11
trebor's Avatar
I cant wait to get my Smoothy. I heard they are so awesome. woo-hoo.
trebor is offline   Reply With Quote
Old 05-23-2007, 09:39 PM   #12
Ohhh dang sorry, I was in a hurry when I posted that, Sorry
Old 05-23-2007, 09:59 PM   #13
gubbs3's Avatar
I haven't seen anyone use one of those pipes in a long time. They used to work pretty well with the old o.s. CZ and CV's. On most new, more powerful engines, it seems they turn most engines into a light switch. Very snappy on the low end and somewhat restricted on top. A lot like the AE torque pipe, but more extreme.
Old 05-23-2007, 11:32 PM   #14
alana07's Avatar
thanks for the info, i'll be getting a OS CVR very soon, looks like i'll give it a try then.
没有最好,只有更好!!!
Old 05-24-2007, 12:55 AM   #15
MadRacer's Avatar
Thanks guys. I knew about tuning the pipe with the manifold, Im happy with the Drake pipe.. Have ordred a new Dynamite off road pipe to see how it goes.
Thanks.. Mark.
pipes brianhatesnitro Onroad Nitro Engine Zone 17 03-22-2007 09:04 PM
Best pipes for an OS RG Cain Electric Off-Road 2 02-24-2007 08:20 PM
.21 RB Pipes. go1d1e R/C Items: For Sale/Trade 4 06-10-2005 01:55 PM
Pipes? Robster Electric Off-Road 2 07-15-2003 01:17 AM
In-line pipes versus old style pipes for .12 engines Hammer0412 Nitro On-Road 25 07-18-2002 12:19 AM
