Old 05-23-2007, 09:47 AM   #16
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Well, if you read the mags and talk to the pros, its how they do it. Tuning by temps is a bad idea. If you do it this method (the way I posted) you still have enough lubrication. Dont lean past max speed or acceleration as that IS hurting it.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 05-23-2007, 10:22 AM   #17
I wasnt thinking about how a noob should tune....my bad. Even so, if they want to do it right, tune by performance, not smoke and temp.
Old 05-23-2007, 10:41 AM   #18
even rody says tune so there is still smoke
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 05-23-2007, 12:08 PM   #19
^^^I'm not saying try to get rid of the smoke, but its best to tune by performance. I know with my WS7II and the current JP1 pipe that I am running, the low end produces mass amounts of smoke. However, yes he did say that is a decent indicator that you are not too lean.
Old 05-23-2007, 01:12 PM   #20
gubbs3's Avatar
This is a quick graph I made that shows how the mixture affects power and heat. The best setting is the circled corner. As you lean the motor out it will gain power very rapidly until it reaches the optimum setting. Anything beyond that will yield very little gain in performance and will build heat quickly. This is why using a temp gun, of any type, is just a way to tell when there is something wrong or you have gone too far. Example: If you're running slobbering rich at 170 and you lean it an hour, it may run fast at 180, another hour and you may be blistering fast at 200, if you go another hour you might get slightly faster but your temps may rise to 240. That's when you know you've gone too far and should back it out a little.
gubbs3 is offline   Reply With Quote
Old 05-23-2007, 01:31 PM   #21
Suspended
Send a message via AIM to Nay0k
The VSpec likes to run pretty hot (in my experience atleast), so anywhere from about 220 to 260 degrees fahrenheit should be good.
Nay0k is offline   Reply With Quote
Old 05-24-2007, 02:44 AM   #22
motomanpat's Avatar
Just remember that at about 300 degrees or so with the crank out of the engine the bearings basically fall out of the motor,food for thought.My V-Spec runs at about 210 or so with 30% two shims plenty fastI am running it in my CRT now all 10 lbs of her.Tuning is an art and you need to learn how to do it not only for motor longevity but so you have good power throughout the range.I am still learning and with the help of other people who have the experience it helps alot.
motomanpat is offline   Reply With Quote
Old 05-24-2007, 06:33 AM   #23
dabro15's Avatar
+1
dabro15 is offline   Reply With Quote
Old 05-24-2007, 09:48 AM   #24
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
i keep mine around 220 -230...
MADMAN23 is offline   Reply With Quote
Old 05-24-2007, 12:09 PM   #25
joe of loath's Avatar
i keep mine at room temp... coz it don't run
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 05-24-2007, 02:28 PM   #26
MADMAN23's Avatar
get that nitro r/c going ..lol smell the nitro .. fling some dirt .. then clean it all...
Racers Edge HIGH TEMP BRAKE DISCS Vsfriedmugan Nitro Off-Road 0 08-11-2008 05:53 PM
WTT high torque servo or PS for temp gun OOde R/C Items: Wanted to Buy 0 04-23-2007 06:19 PM
FS NIP VENOM SMART/ TEMP (fail safe and on-board temp gauge) factory racer R/C Items: For Sale/Trade 7 07-02-2006 11:49 PM
Raytech mini temp temp gun Art Jensen R/C Items: For Sale/Trade 4 11-19-2005 08:31 AM
Wanted Temp Gun Or Temp Device BC_R/C_RACER R/C Items: Wanted to Buy 4 05-29-2003 07:35 AM
