Idle Problems
I recently bought a HPI nitro mt2 and I am having problems with idle I have to adjust the throttle control on the controler so far advanced so not to stall that if I do not have the breaks on it pritty mush goes full speed.
you need to turn up the idle screw on the carb. using your radio trim to do that is very hard on your servo. look to your manual to see how your idle is adjusted by the screw. or look on hpiracing.com to look up the maunual if you lost yours.
