Old 05-18-2007, 08:59 PM   #1
ERustler's Avatar
Send a message via AIM to ERustler
Exclamation Mounting a Mamba Max
i need to mount a mamba max esc onto a electric rustler, and it has no mounts. i need to be able to get to the usb hookup(duh ) so i was going to use the plastic plate in front of the XL-1 esc mounting place. but i need to know how to do that, do i glue it on, or what?
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
There is no such thing as budget RC.
ERustler is offline   Reply With Quote
Old 05-18-2007, 09:48 PM   #2
if it's a rustler that came with the XL-5 throw some double sided servo tape on it and if it's a XL-1 throw the X-5 plate onto it then the servo tape
car:losi 8ight
engine:werks B3, Novarossi P5XS
radio:DX3R,Ace DS1313
vroom88 is offline   Reply With Quote
Old 05-19-2007, 07:28 AM   #3
ERustler's Avatar
Cool servo tape?
can i just get servo tape at a normal rc habby shop?
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 05-19-2007, 07:57 PM   #4
yes
car:losi 8ight
Old 05-19-2007, 08:50 PM   #5
Trader Rating: 35 (100%+)
Or get Velcro tape, that is what I use.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 05-20-2007, 12:15 AM   #6
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
If you have one of the rustlers that had a msc you can get a rpm mount and just use double sided tape or velcro so you can pull it off to get to the usb easier
http://www.rpmrcproducts.com/product...as/chassis.htm
Cheers
Drift_Buggy is offline   Reply With Quote
Old 05-20-2007, 12:32 AM   #7
yes, thats what i did, velcro
mitchellmoxon is offline   Reply With Quote
Old 05-30-2007, 11:25 AM   #8
ERustler's Avatar
ya i ended up using the battery plate in front of the xl1 esc, you can turn it a little and use the other screw hole into where the esc mounted, then used servo tape.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 06-05-2007, 07:31 PM   #9
Talking
After some of the jumps I have done with the 7700 I had to tiestrap mine. Tape and velcro dont hold up to 10' to 12' backflips over hondas. LOL
beanie is offline   Reply With Quote
Old 09-12-2007, 12:35 PM   #10
ERustler's Avatar
i just ended up mounting it in the middle, with one of the plates, and put masking tape over the USB port to keep the dirt out and havent had any problems.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Mounting a Fan surrealmaterial Electric On-Road 30 01-24-2007 07:22 PM
Brushless mounting Racingfreak6 Electric On-Road 11 01-07-2007 12:14 PM
need pic with fan mounting pinggoy Electric On-Road 5 10-11-2006 11:57 AM
DNA-1 Wing Mounting or8ital Electric On-Road 9 09-05-2006 09:38 PM
Fan mounting Mark G Electric On-Road 4 06-06-2006 12:41 PM
