Old 06-06-2007, 09:16 PM   #46
Orange's Avatar
[QUOTE=Wild Cherry;3370095]
Originally Posted by Orange View Post
I don't think that the bump up thing will happen. Not to say I don't like the idea, but I think that a racing program needs to stay course and all the classes shoud be done the same for the most part. In this case the only thing that is different is the time for the mains and qualies. It could be possible to allow the other types of motors though.... Not my call, but maybe it can be brought up during drivers meeting and discussed a little. I certainly don't have any problem with it and I do not think anyone else would either.
Personally though, if there is to be a class that is touted "The electric class of the future" then don't you think that maybe the suppposed "Products" that are touted as the "Future" of the sport should be promoted as such? Not to abandon any of the brushed stuff, but really I think that the class needs to be signified to one type of motor rules so that it doesn't get too complicated to tech in the future. Not only that, but the class is pretty much a brushless type of race. Even if they are allowed, I do not think you will see many, if any, that will try to run a brushed motor.
And if you think about it... We have Stock (A brushed class) 19t (Brushed) and Modified (Brushed/Brushless mixed). Maybe there should be a class designated only for Brushless?
Brush motor`s can do this type of racing , just use a light spring, a set of XXX brush`s and gear down a bit ...
A brush motor can run up to 10 hr`s continuously this way ....
We do it all the time ....
George: I agree totally. I certainly do not have the power to change the rules, but maybe if it is brought up at the race to the ROAR officials, maybe it can be changed to also allow brushed motors... It is a Demo class and basically a start to something that will I'm sure be a great thing.
I think this is the best way to start a class of racing... You get it at ROARs premier race in front of all the who is, a simple basic set of rules to follow to keep it easy and once it is over, then we can see where things need to be fixed and how they can be fixed by getting a good set of guidelines drawn up. This is simply a place to test the waters thats it. This isn't a worlds qualifier race so to me it is the perfect time to do a test run.
Orange is offline   Reply With Quote
Old 06-06-2007, 09:24 PM   #47
Sean
I am just thrilled to see you add the class and don't really care if you change it or not...I just want to race!
Thanks for you and Dawn calling into the radio show tonight that helped me out answering questions about the race. You know the show is archived to listen to it later here http://www.racetalklive.com/broadcast.asp just click on the 6/6/07 show date to download.
Look forward to meeting you guys and find out where all the good eatting places are located.
Craps is offline   Reply With Quote
Old 06-06-2007, 09:37 PM   #48
Orange's Avatar
Originally Posted by gndprx View Post
Regarding what brushless makes a 20 min race...
I have run both the Mamba Max 4600 and 5700 and both will easily make this run and then some with no worries. MaxAmps 8k Lipo with a 5700 running 17/87 is what I will be running for summer nitro fest at The Farm this coming weekend. After a 20 min run plus a few minutes of warm up on a short tight track, I don't believe I have topped 160 degrees at the can and 130 at the ESC. They are rated to 200.
The castle systems offer huge torque, but can be a bit fussy on the cogging issue if you are a "trigger pulsing" style of driver. They like smooth trigger a little better.
We do have a regular showing of brushed motors in the 20 min main though and one that is a consistent winner...
I have no doubt that brushless motors can go the distance... I have no doubt that brushed motors can go the distance... I have some reserve on whether or not electric cars as they are designed can weather the longer mains but that is just me, I have never raced an electric car for longer than 5 minutes.
As far as this track goes.... This is not the Farm. It is only 110' x 75' or so. The surface is like driving on Asphalt with jumps (When I say asphalt with jumps, I mean it. just like it says)... Not loamy at all... As a matter of fact, they prepare the surface with sugar and water for extra traction.... This will be unlike any track that some people have ever seen or will ever see. I am very sure that because of this traction, some of the people that are not used to it, WILL thermal on their first runs on the track. Some will show up with 5.5's, 6.5's, and end up using 7.5 or higher. The extra traction equals heat and shorter run times...
Ya'll don't believe it now, the testomonials to this statement will come after the race is over. I gaurentee(<~sp?) it.
Old 06-06-2007, 09:39 PM   #49
Orange's Avatar
Originally Posted by Craps View Post
Sean
I'm sending you a PM for Tire Info... I don't think I got it all out tonight.
Old 06-06-2007, 09:46 PM   #50
Losi Taper Pin Silvers in the front
Losi Taper Pin Reds in the rear
Trinity Bomb 1 Ultra firm foams in both
Do I need to burn the Losi tires? (You know what I mean!)
Do you think pinks will work up front? I have a bunch of those and can't find silvers.
I hope somebody will be there selling tires?
Old 06-06-2007, 10:01 PM   #51
Orange's Avatar
I do not recomend Pinks.
I do not recommend fire.
Another PM....
Old 06-07-2007, 05:14 AM   #52
Another PM....
Thanks!
I just thought pinks felt alot like the silvers with the reds being very different.
Thanks again!
Old 06-07-2007, 12:39 PM   #53
I talked to Tebo out at the Farm Raceway today where he was practicing for Summer Nitrofest and he said he was not racing in the Li-po/Brushless Truck Class at the Nats and that Checkpoint's brushless motor was not available to him yet.
Old 06-07-2007, 05:05 PM   #54
chrlie sidebite's Avatar
Ok now if this goes.......Can old dudes (Master) bring a chair to the drivers stand?
chrlie sidebite is offline   Reply With Quote
Old 06-07-2007, 07:49 PM   #55
I am racing in the Masters class and I perfer the longer race that with age comes experience, wisdom and patience to not break letting the kids break and burn they're tires up so us old dudes have a chance!
Old 06-07-2007, 08:37 PM   #56
Jerry23's Avatar
that was my plan. hope that doesnt mean im starting to get old...
www.JerryRoyJr.com
Thunder Tiger/Mikes Hobby Shop/GulfCoast Raceway/Amsoil/Pre-Paid Legal
Jerry23 is offline   Reply With Quote
Old 06-08-2007, 12:15 AM   #57
Of course Associated and Losi had to come out with quick change wheels on the back!!!!
Old 06-11-2007, 06:53 AM   #58
2007 ROAR On Road Electric Nationals Anthony.L Electric On-Road 685 08-03-2007 12:58 PM
class added to ROAR Off Road Electric Nats - just FYI Dawn Sanchez Electric On-Road 11 05-20-2007 12:52 AM
Provisional Class Added to ROAR Off Road Electric Nats Dawn Sanchez Racing Forum 1 05-19-2007 08:19 AM
2007 ROAR On Road Electric Nationals *** VENUE CHANGE *** Dawn Sanchez Racing Forum 1 05-17-2007 05:34 PM
2007 ROAR On Road Electric Nationals Dawn Sanchez Racing Forum 0 04-15-2007 11:15 AM
