Old 05-17-2007, 12:26 AM   #1
Default xxx 4 Drag in Drivetrain
Hello all,
I just bought a xxx-4 recently, and am new to the 4wd buggy scene.
A few weeks ago, the car was running great, until I broke the chassis. After replacing the chassis, there seems to be drag somewhere in the drivetrain. The car is slower overall, and when I go over a jump, the back end comes up, like I'm applying brake. In general, the car drives like it has drag brakes.
I checked the Novak 5.5 system, re-programmed it, checked all radio settings, and the problem doesn't seem to lie there. The diffs need to be rebuilt, but I wouldn't think those would be a problem.
With the motor removed, there seems to be friction when you turn the wheels. I currently have the HD belt and pulley system installed.
Has anyone come across this problem? It could be a bearing, but at what point do you replace belts? Do they stretch?
Also, I have the carbon fiber mod on the front diff case. Aside from tearing the car down completely, I wanted to know if there are any problem areas in the drivetrain so I can focus my efforts there first.
Any help would be greatly appreciated. Thanks!
Eggman is offline   Reply With Quote
Old 05-17-2007, 12:55 AM   #2
Trader Rating: 96 (100%+)
Is the slipper assembly in the right way? There's a few shims and bushings that if not put in the correct order will affect the belt, or they may be missing altogether.
K.Copeland is offline   Reply With Quote
Old 05-17-2007, 08:17 AM   #3
Trader Rating: 58 (100%+)
In addition to the above, Don't get the belt overly tight. It tends to drag it a bit.
Where ever I may roam
Bigcheese is offline   Reply With Quote
Old 05-17-2007, 09:59 AM   #4
Slipper Assembly is installed correctly.
Belt tension seems to be ok.
Old 05-17-2007, 10:11 AM   #5
portyansky's Avatar
Trader Rating: 54 (100%+)
I dont have a xxx-4 but if you say your diffs need rebuilding, then I would do it. Check your belts and slipper assembly as well.
Good luck....
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 05-17-2007, 10:40 AM   #6
Since it happened after you replaced your chassis, I'd check to make sure the belt isn't hitting anything first. It only takes a little to make it drag. If teh belt's clear, check your bearings. I'd check the ones in the slipper assembly and in the tensioner pulley first.
cjtamu is offline   Reply With Quote
Old 05-17-2007, 03:03 PM   #7
Alltapdout's Avatar
If the tensioner hex is not tight enough/ or the washer with the elbow cut in it, is inserted wrong, the adjuster hex with contact the idler arm and cause drag.
There are two bearing in the slipper assy.
If you have the new machined idler gear then there are two bearing in it... If you are running the origional white pulley be sure to check that...I've replaced a few of those bearings...hense the upgrade.
Finally be sure to rebuild diff's and clean the side diff bearings..
Other than that...? Maybe the steering box insert is loose and causing drag.
Is you belt starting to fray??....If so I suggest a new one. A new belt is like a entire new car!!
Alltapdout is offline   Reply With Quote
Old 05-17-2007, 04:56 PM   #8
Make sure the giant slipper tension nut isn't dragging on the belt tensioner. I bought mine used, and it was rubbing badly. A shim or two fixed it easily.
AE FT B44.2, SC10, T4, B4.2, B4, 18T, 18R, TC4, L3.5O ** Losi MRC Pro ** CRC Carpet Knife ** Axial XR10, AX10, SCX10 ** Traxxas EMaxx ** JR Z1
Manning is offline   Reply With Quote
Old 05-19-2007, 12:48 AM   #9
Well, after I pulled it all apart and inspected everything, I took a look at the belt and it was frayed a little on one side. I put a new belt in, and voila, she's back to new.
I had no idea a slight fray would make such a big difference.
Thanks to all those that helped and posted replys.
Old 05-19-2007, 08:54 AM   #10
Alltapdout's Avatar
Ah ha. Glad to help sir! Good to hear everything is running smooth!
How free is your drivetrain? seaball Electric On-Road 121 04-21-2013 12:15 PM
Beef Up Drivetrain BuggyKing Micro and Mini Scales 11 10-23-2007 09:41 AM
tc3 drivetrain kh15 Electric On-Road 10 09-05-2004 09:38 PM
Drivetrain problem Committed88 Electric On-Road 9 05-10-2004 03:19 PM
Drivetrain Belt Potato Electric On-Road 1 08-05-2002 08:53 AM
