Old 05-16-2007, 09:32 AM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Default Possible Droop problem with RTR T4
I picked up a used RTR T4 to have my daughter run at the races, and I noticed that the rear droop doesn't look very good as the arms hit the rear dogbone axle cup. If this contact wasn't there, alot more droop could be achieved.
Is it commone that this is a limiting factor in droop? Should the cups extend in so much that they can on droop hit the suspension arm bracing piece that is close to them.
And before you ask, no I don't have the arms mounted upside down.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 05-16-2007, 11:22 AM   #2
annie_himself's Avatar
Send a message via AIM to annie_himself
If it's for your daughter then she shouldn't care at all but all you need to do is trim a little material from the hub and you'll be fine.
annie_himself is offline   Reply With Quote
Old 05-16-2007, 12:26 PM   #3
Tech Legend
Cain's Avatar
Thats true but I want to make sure that its built right.
Looks like this may be just how it is I guess. Will take pics later on.
Old 05-16-2007, 06:34 PM   #4
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
Please try to check the rear shocks. The previous owner might have missed the spacers. There should be 3 x 1/32" downstop spacers inside (see manual).
Hibernating...
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 05-17-2007, 12:19 PM   #5
Tech Legend
Cain's Avatar
Will do.
Can anyone shoot me a pic of how the rear of there T4 looks droop wise? Maybe its just me being used to something else.
Old 05-18-2007, 06:03 AM   #6
swopemike's Avatar
You're probably not imagining it. I had the same issue on my son's T3. Mine for some reason was no issue.
However being race day I took the fast easy way out. Dremeled on the arms a bit to let it clear. Thanks for the comment on the shocks... I wondered why this happened. Makes sense.
swopemike is offline   Reply With Quote
Old 05-18-2007, 10:30 AM   #7
crazyjr's Avatar
Be careful if running dogbones, It sounds to me like someone took out the spacers in the shock for more travel. if you are running bones Put a small piece of fuel tubing in the pockets for the bones to sit on and be centered. I had the older T4 rtr and did this for more travel but lost a few bones till i figured it out
crazyjr is offline   Reply With Quote
Old 05-18-2007, 12:31 PM   #8
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
MIP CVD axles would be the easiest and best way to go. You wouldnt loose dog bones either.
OG RC 10T is offline   Reply With Quote
Old 05-19-2007, 06:35 AM   #9
jobo_ph's Avatar
Will do.
Here you go...
You can also check if the eyelet is fully screwed into the shock shaft.
Hibernating...
Old 05-21-2007, 12:43 PM   #10
Tech Legend
Cain's Avatar
Thanks guys, especially for the pic. Really isn't too much droop then, will be more by default on the cvds than the dogbones as the axles go out so far.
I'll look and see about some CVDs, though the dogbones can work in the right conditions, so will hold onto them as a tuning aid.
Hudy droop guage, ae droop guage, ae ride height guage Midnight R/C Items: For Sale/Trade 7 09-02-2008 09:43 AM
950r front droop problem - can you help? TC_Tuner Nitro On-Road 11 07-18-2006 08:41 PM
setting droop on droop blocks mrgsr Nitro On-Road 3 01-08-2006 07:01 PM
Droop Intermision Rookie Zone 9 10-16-2003 09:55 PM
