Old 05-14-2007, 08:19 AM   #1
S. Howard's Avatar
Default Track prep with Calcium chloride
Just looking for information or suggestions from guys who have used Calcium chloride on their tracks. I'm looking for where you would purchase it and how you calculate how much to use.
thanks
scott
S. Howard is offline   Reply With Quote
Old 05-14-2007, 09:28 AM   #2
The purpose of adding calcium chloride is?...
Next, is it laid on the surface or tilled in to the soil?
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: [email protected]
satoch is offline   Reply With Quote
Old 05-14-2007, 09:41 AM   #3
It makes everything metal on your car rust.
Tekno RC, Alpha Plus Engines
AKA Products, Lutz RC, A-Main Hobbies
NitroPro Fuel, Hot Headz Engine Heaters
Raceform Bodies.....Reilly Paint (Just Plain Wicked)
gasser is offline   Reply With Quote
Old 05-14-2007, 10:00 AM   #4
S. Howard's Avatar
it's purpose is to help the dirt pack down.
Old 05-14-2007, 10:29 AM   #5
It makes it hold water
no1uno is offline   Reply With Quote
Old 05-16-2007, 02:16 PM   #6
Trader Rating: 58 (100%+)
It will make the top layer cake & break off leaving ruts. There are better soil conditioners. gypsum is one. It helps hold moisture. I've heard of guys using fine mulch. Even sawdust.
Where ever I may roam
Bigcheese is offline   Reply With Quote
Old 05-16-2007, 03:52 PM   #7
mremtr's Avatar
Don't use calcium ! that stuff is horrificly corrosive !!! Use a good base material such as pond silt and then stiffin it up with gypsum or lime, lime gives a bit more grip if you get the coarse ground stuff. It will be like racing on 80 grit sandpaper ! And it will lighten up the soiil color so the blue groove shows up very fast
mremtr is offline   Reply With Quote
Dirt Oval track prep genesisG4 Oval, Larger Scales and More 7 12-12-2007 06:12 PM
Tire Prep Fewski Rookie Zone 2 01-06-2006 12:41 AM
Calcium Lingo Sulfate???? nitro or nothin Electric Off-Road 1 05-21-2004 08:32 AM
Outdoor clay track prep? snopro31 Electric Off-Road 15 04-24-2004 11:35 PM
Calcium Chloride application RedDragonRacing Electric Off-Road 1 02-16-2004 04:00 PM
