Old 05-13-2007, 10:46 PM   #1
sheetmetal2's Avatar
Default Turmoil Setup
Brand new to 1/8 scale. We have run a elec trouring car and 10th scale gas truck. Got a new turmoil buggy and I am wondering what to run for a setup right now it is right out of the box. Is this a good starting point or is there something I should change? I have read alittle about tuning with diff oils. Can anyone shed any light on this or is this something I don't need to worry about for some time? Any help is appreciated.
www.rcxracing.com
Rc10 Gt EDM
M&M Racing Klien Sprint Car
Losi Mini T
sheetmetal2 is offline   Reply With Quote
Old 05-14-2007, 08:36 AM   #2
Trader Rating: 26 (96%+)
You will need to go through the entire car. Any screw that is in metal needs to be blue thread locked. Any screw that is in plastic needs a dab of ca. Then go and break in your motor. This will also allow your diffs to break in at the same time. Once your motor is broken in pull the diffs out of the car and completely clean them out. For a setup I would start with this right here. This is a great setup. If you are on a smoother track then I would switch to like a 7 in the middle.
front shocks 45 wt Losi and grey springs
outer hole on the arm and middle hole on the upper row on the tower
Maximum caster
2 deg. camber
2 deg. toe out
center hole on the ackerman bar
Stock 2.2mm (black) sway bar
bones level
rear 35 wt Losi with Xray white springs (just a bit softer than the SW reds)
outer hole on the arm and middle hole on the lower row on the tower
0 rear anti-squat
3 deg rear toe
2 deg. camber
soft 2.5mm (Gold) sway bar
bones level
5,5,3 in the diffs
party_wagon is offline   Reply With Quote
Old 05-17-2007, 06:58 AM   #3
Default set up
Thanks alot
www.rcxracing.com
Rc10 Gt EDM
Losi Mini T
Old 05-17-2007, 09:45 AM   #4
Hey I have seen that set-up before! LOL
Tekno RC, Alpha Plus Engines
AKA Products, Lutz RC, A-Main Hobbies
NitroPro Fuel, Hot Headz Engine Heaters
Raceform Bodies.....Reilly Paint (Just Plain Wicked)
gasser is offline   Reply With Quote
Old 05-17-2007, 10:37 PM   #5
Regional Moderator
FroBoy's Avatar
I guess I like my car a little stiffer...
For my starting setup I run 50 wt oil in the front, with Thunder Tiger red springs. Middle shock position on the tower and inner position on the arm. Unscrew the shock end two turns. Caster all the way back.
Middle hole on the ackerman. Also, make sure your steering servo is in the upright mount, not laydown.
40wt in the back, X-ray white springs... ( I also like Mugen Grays, too. depends on how bumpy the track is.) I also drilled out the pistons to make them a little bit larger, don't know exact size...just a little larger. Outer top shock position on the tower, outer position on the arm.
Hubs centered, 1.5 degree of anti squat. Camber link position inner lower position on the tower, inner hole on the hub.
2 degrees of camber all the way around, if you're catching ruts try a little more camber on the front. I also run about 2 degrees of toe out. Also, keep your ride height slightly above arms level front and back.
As far as the diff oil goes. I start at 5,7,3, if the track is slick I go to 5 in the middle and 2 in the back.
Team Losi Racing, Spektrum, Dynamite, Thunder Power, HobbyTown USA Hobbyplex
Proud member of the Scale Hobby Interest Team!
www.hobbyplexraceway.com
FroBoy is offline   Reply With Quote
Turmoil PRO manynitros R/C Items: For Sale/Trade 11 06-03-2008 06:46 PM
Turmoil PRO manynitros R/C Items: For Sale/Trade 0 05-20-2008 07:42 AM
SPORTWERKS TURMOIL PRO SETUP superx421 Nitro Off-Road 7 02-19-2008 10:30 AM
Turmoil Pro w/.21 Bigcheese R/C Items: For Sale/Trade 11 03-23-2007 06:10 PM
Turmoil Pro leviathen79 R/C Items: For Sale/Trade 0 02-20-2007 05:50 PM
