Old 05-13-2007, 12:02 PM   #1
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Mini Toink Send a message via Yahoo to Mini Toink Send a message via Skype™ to Mini Toink
Default Shaft vs. Belt...
Hello Guys,
I'm thinking of buying an offroad 4WD buggy and would like to know what are the advantage and disadvantage of Shaft driven bugs(JConcepts BJ4WE) & Belt driven bugs (TAMIYA TRF-501X / Yokomo MR4-BX).
Is it more advicable to get Shaft or Belt driven 4WD bugs?
Thanks in advance for the help guys!
Toink
Xray T2'008 EU 6Cell
Hudy Pro Tools
AE 12R5
LRP : Orion : Sanwa (Airtronics) : Ko Propo : Spektrum
Mini Toink is offline   Reply With Quote
Old 05-13-2007, 08:49 PM   #2
Default Shaft vs Belt
Shaft is sealed, belt tends to get dirt, debris in it, means more upkeep and service. Biggest advantage that I have noticed is when adjusting the pitch of the car in mid air. With Belt everything is spinning the same direction so it is very responsive to throttle adjustments. My Lazer would tilt to the side when I was throttling it to adjust the pitch. Just my opinion.......
DBBIndy is offline   Reply With Quote
Old 05-13-2007, 09:32 PM   #3
sport10's Avatar
Using a sealed belt system like the one on the Losi buggies keeps alot of the dirt out. A well designed belt system is low maintence and the belt absorbs alot of the abuse offroad tracks dish out making the driveline components last longer too. The Yoke's belt system is not sealed and needs regular cleaning to keep it free. Check out the Xfactory X-5 for a more sealed belt drive system.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 05-14-2007, 11:42 AM   #4
johnnyboy's Avatar
Trader Rating: 28 (97%+)
I have had both a BJ4WE and a Yokomo MR-4BX. Both drive pretty similar if set up correctly.
Yokomo Pros:
extremely bomb proof front end
great in the bumps
easy to drive, smooth on the power delivery
Yokomo Cons:
rear diff takes a beating. I have to rebuild after every meet if it is dusty out. (easy to take out though)
belt tension is something I have to learn about and can be a pain to adjust.
lack of support in North America for set up & info
BJ4WE Pros:
very low maintenance
lots of support
very quick response wise
BJ4WE Cons:
I don't care what people say, the front end is still fragile
slightly twitchy feeling throttle wise
Personally there are good and bad for the both. I like the handling of the Yoke, but I miss the sealed drive train of the BJ4WE...and well...I just have been brainwashed to not drive Losi cars...
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 05-14-2007, 12:18 PM   #5
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Belt driven offer smoother accelaration than shaft driven cars. Shaft driven seem to be more punch like the Bj4 car.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 05-14-2007, 03:05 PM   #6
R40Victim's Avatar
Not sure if the issue is the same in off road, but in on road, shaft drive is only good stock through a decent 19T motor. Belt drives handle the low turn mods better. I watched the shaft in my Pro 4 just about jump out of the car at full throttle, and that was just a GTB 5.5 I then installed a brand new shaft to be sure it was straight...same problem. It's the same story in my TC3, the reaction to the 5.5 is pretty violent. I don't know if it's an issue in the cars you're looking at. The Losi XXX-4 on the other hand, does very well with a low turn mod, or high performance brushless system.
R40Victim is offline   Reply With Quote
Old 05-14-2007, 06:14 PM   #7
BuggyKing's Avatar
With a rough track the XXX4 doesn't drive as well like the XX4 and BJ4.
RIP Mike M
Old 05-14-2007, 07:02 PM   #8
GymBeam's Avatar
Originally Posted by johnnyboy
BJ4WE Cons:
agree
GymBeam is offline   Reply With Quote
Old 05-14-2007, 07:17 PM   #9
Noah R.'s Avatar
I have a XXX-4 and personally I think the front end is fragile. Allways breaking parts on the front end. Land on 1 wheel and your screwed. Plus if you get smacked in the air by another car say goodbye. Alot of people at my track run BJ-4s and some XXX-4s and the poll is the BJ4. One of the guys runs an all alum front end except for spindles so the spindles take alot of punishment but he dosnt break much more. I personally like the smooth feeling of belt and the sealed drivetrain is very nice but the slipper clutch was a pain to break in ( Had to rebuild it with a rebuild kit 2 times). Heres one word of advice if you buy a new xxx-4, break the slipper in with a stock motor for a while, then move to a heavy modified (ran it a couple times with stock then put a 5800 in it). As a conclusion it depends on your driving style period end. Do you drive with a punchy attitude or with a smoother attitude.
Noah R. is offline   Reply With Quote
Old 05-14-2007, 09:38 PM   #10
Default Yokomo is tough
I have crashed my Yokomo harder than I ever thought possible and it takes far more abuse to break anything than the kyosho I had, or the B4 I also run. The Yokomo is more labor intensive between outings, but I get a LOT more running in while at the track since it seldome breaks. I know the best solution is to not crash but if you are new to the speed of 4 wheeling, track time is king.
Old 05-15-2007, 06:58 AM   #11
Alltapdout's Avatar
Is it a G+??? I've had mine for 3 years and only broke one front graphite pivot and two spindles in the front...Went to alum pivot!! And I stoped braking things...I just drive within the abilities of the vehicle! I do really like the butter smooth belt drive though.. And I was reading earilier and it kinda made sense..but... can you adjust the pitch of a shaft drivin car in the air??
With a belt, brushless, n a good battery pack you can pull the front end over the rear then hit the break and bring the front end right back down...It amazes people @ the track everytime!!
Alltapdout is offline   Reply With Quote
Old 05-15-2007, 04:43 PM   #12
Noah R.'s Avatar
Yeah i'm running G+. I only break on one of the nearly 20 jumps at our track. Its beacuse of the way the landing is. I drive within its limits but have to say that belt is better for air controll.
Old 05-15-2007, 05:29 PM   #13
Alltapdout's Avatar
Thats what I was thinking!
Old 05-19-2007, 05:32 PM   #14
i had a losi XX4 world buggy and it was a sealed belt drive system worked great no problems gotta love the front clicker....
joenitro* is offline   Reply With Quote
Old 05-20-2007, 04:55 PM   #15
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
I have a Yoko and i thought that thing was great till i ran my friends BJ4. With my belt it felt like it was loose the shaft in the bj just feels like it hooked no give. I like the way that felt
wd40prerunner is offline   Reply With Quote
belt vs shaft keavze Nitro On-Road 3 07-09-2007 03:57 PM
Belt vs. Shaft axel Chat Lounge 27 04-08-2005 06:59 PM
Belt or Shaft? ? ZER01 Electric On-Road 67 05-25-2004 10:18 PM
Shaft or belt? NetBike Nitro On-Road 23 05-13-2004 11:45 AM
Shaft vs. Belt again was ist los? Electric On-Road 55 10-10-2003 12:41 PM
