Old 05-19-2003, 02:59 AM   #16
akrcracer's Avatar
I once ran a xx-4 on carpet too. I lower it(chassis to carpet) . Ran 70 wt in shocks.limit droop with spacers inside shocks. Removed slipper. Put street weapon shaft in. Beacause can blow out slipper running on carpet. I ran foams on wheels foams cut to small dia. hope this helps.
akrcracer is offline   Reply With Quote
Old 05-19-2003, 03:05 PM   #17
How would I take out the slipper? Will this improve performance? I understand that most 4wd racers do this.
mr. chicken is offline   Reply With Quote
Old 05-23-2003, 04:56 PM   #18
Anybody? Slipper removal?
Old 05-23-2003, 09:16 PM   #19
traxxasdude's Avatar
I'm guessing but tighten it all the way?
traxxasdude is offline   Reply With Quote
Old 05-24-2003, 12:53 PM   #20
I'll try that until I can find out how to remove the slipper.
Old 06-02-2003, 04:33 PM   #21
I've now locked down the slipper. I still don't know how to remove the slipper. Help!
Old 06-02-2003, 09:36 PM   #22
dirk's Avatar
80 wt oil seems a bit thick, almost like honey. I use 30 wt and it works well... but I use a 2wd, sorry I was just shocked at the oil thickness you use!!
dirk is offline   Reply With Quote
Old 06-03-2003, 04:27 PM   #23
I think i-d be good with 60 wt. or less. Is that a picture of Brian Kinwald, the Dirtinator?
Old 06-03-2003, 11:14 PM   #24
dirk's Avatar
YUP!
Old 06-04-2003, 08:46 AM   #25
I am now reassembling the car. It wasn't built quite right, and, hey, it's fun to drive a car that YOU built. I'm now done with the drive train and steering assemblies. According to the LHS, I want the "front end to pull the car through the turns", so I tightened the front diff and left the rear alone. I've also got to raise 190 dollars to pay my dad back and get some new batteries. The old 2000's overheated and now won't hold a charge. I'm thinking Reedy 3300's. I'm going to need a new charger, and the LHS has a bunch of Super Brains in. Those cost 69.95. I need to make some money.
Old 06-04-2003, 08:49 AM   #26
I just learned that Dynamite has A 2000 saddle pack availible, along with GP 3300's[not assembled].
Old 06-04-2003, 01:09 PM   #27
dirk's Avatar
Yeah, I love building the cars.
I use the super brain 819, its so practical.
Tight track RKeasler Electric On-Road 2 04-16-2008 09:32 AM
wats a good setup for a xxxs for rubber on carpet track?? Carpetracer92 Electric On-Road 2 01-22-2008 06:17 PM
Need a Setup For TC4 Team Carpet Track SammyZ Electric On-Road 2 02-08-2006 09:35 AM
The best setup for HPI Pro4 on small carpet track? Ingvar Electric On-Road 0 11-06-2005 10:40 AM
Tight Track Rollout fatdoggy Electric On-Road 8 11-14-2003 02:03 AM
