Old 05-11-2007, 12:55 AM   #1
Trader Rating: 96 (100%+)
Default Idle issue/lean condition ?
I'm not new to engines but this one has me stumped. OS RG, great compression, everything except the hs needle has been sealed, oring on the hs needle is good. New car, new fuel tubing, fuel tank seems good( should be, it's new) , no visible air bubbles in the lines, exhaust pipe checks out ok. I even bought another fuel tank just to eliminate the stock tank.
Engine idles fine and can be as rich ( both high and low needles) as Trump but will idle fine. Give it some throttle and the rpm's come up but then it starts running as if it's lean and the idle doens't go back down like normal, rather after a few seconds the idle will come down .
Any info/help would be much appreciated.
K.Copeland is offline   Reply With Quote
Old 05-11-2007, 07:35 AM   #2
houston's Avatar
Trader Rating: 91 (100%+)
Talking
its because its too fat on the bottom eddy !!! its burning off the unspent fuel in the crankcase is the reason why it idles high for a few seconds after throttling up and then letting off !!! make sure your high needle is plenty fat before leaning out the bottom to a good crisp throttle response !!!
good luck , monty
TEAM FUSION X ENGINES /RC-OMG USA/ TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-11-2007, 07:49 AM   #3
d4man's Avatar
If you have the manual, refer to it, and put BOTH needles back to factory settings. Yes, the engine will be a little rich. Just as Houston said, adjust the high end needle first , then the low end needle.
Make *small* adjustments!!!!!
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 05-11-2007, 07:53 AM   #4
kevinmajor's Avatar
I agree with houston
1. Warm up the engine
2. Turn in the LSN 1/8 of a turn
3. Bring the vehicle to a stop, count to 5, then floor it. You should get immediate acceleration with smoke from the pipe.
4. Bring the vehicle to a stop. The idle should settle down to normal. If it doesn't, continue to lean the LSN 1/8 turn until you get good throttle response and consistant idle.
Good Luck.
kevinmajor is offline   Reply With Quote
Old 05-11-2007, 08:12 AM   #5
also if you are running a fuel filter make sure there is no restriction in the filter... set the carb to factory setting and retune...
Garrison is offline   Reply With Quote
Old 05-11-2007, 09:11 AM   #6
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
is it runing fine now?
MADMAN23 is offline   Reply With Quote
Old 05-11-2007, 11:00 AM   #7
Thanks for the replies, I'll give it a try later on today. There is no secondary fuel filter.
Old 05-12-2007, 05:50 AM   #8
mremtr's Avatar
Eddy , come down to ETMR and introduce yourself and I will help you tune that bad Larry up ! I eat ,sleep and once, drink nitro LOL, it tastes just like it smells when burnt LOL ..
In all seriousness I can and will help you out ,stop buy ,the track is unreal!!!
mremtr is offline   Reply With Quote
Old 05-12-2007, 08:20 AM   #9
mretmr, ygpm.
Rich? Lean? Normal? duratraxrc Nitro Off-Road 2 08-27-2008 12:41 PM
over lean when no fuel... NitroWD Onroad Nitro Engine Zone 4 03-18-2008 08:55 AM
Dead plug=too lean? keavze Onroad Nitro Engine Zone 6 11-22-2007 08:24 AM
Rich and Lean. R/Cstratus48 Nitro On-Road 1 07-17-2004 10:16 PM
what is too lean?? neopumpkin Electric Off-Road 7 04-18-2003 09:57 AM
