Old 05-11-2007, 12:08 AM   #16
I will check the brushes. It said something about running them with lower voltage to make sure they are seated correctly.
avengence is offline   Reply With Quote
Old 05-19-2007, 10:22 PM   #17
I figured out the problem. The brushes were dirty (even after 2 batteries) anyway I just try to clean them after I put 2 batteries through it. I have a question though... does anyone know if stronger springs help with acceleration or anything?
Old 05-19-2007, 11:20 PM   #18
rustyvan's Avatar
Default some answers to your t4 problem
here is a couple of things check your Gears.once you get the correct gearing do the paper test if you fit a shit of paper between spur and pinion gear then you got the correct gear mesh. Also make sure that there isn't something binding in the drive train because that will slow you down. Also invest in some motor spray so you can spray out you motor. Also read your manual on the speed control to see if it says something about resistors
on the motor because some motors have extra resistors for sautering on depending on what conditions the motor is being used in. Also you where smart by going with deans plugs. The white plugs you have can overheat and expand on the connections inside. Plus with deans you get a better draw power which in return will give you a little more power. also the same can be said for when you switch the bullet connecters on the motor to deans. Also one other cheap item that you can buy that will help you out is called a com stick. what that does is it goes in where the brushes on the motor go and it is a little stick that cleans the com so that way it is clean of debre and smoother for when you put the brushes back into the motor.
That should help you out. Also if you go to get a new speed control check the boards on here like I see novak gt7 go for $50.00 and Novak gtx and other good brands. The 2 I mentioned are a steal when you see them for that price.
rustyvan is offline   Reply With Quote
Old 05-20-2007, 01:25 AM   #19
Thank you for all the advice. I was at the hobby shop today and I got a com stick. It worked well and cleaned it out. I used the rounded side on the brush and then followed it up with a pencil eraser. Cleaned up real well. As far as wiring I am going to replace the stock wiring to the motor and just do a deans plug setup. I am going to run some 12ga wire to it. I also got a new 18t pinion so I should be set for that gearing. It has a LOT more torque now and it takes off a lot harder. I also got m new tires on and all of that. I actually got to drive it so hard that I broke the left side castor block. Luckily I had another one. I am gonna take apart the transmission tomorrow and see what is making the clicking noise. I am hoping its nothing too expensive lol.
Old 05-20-2007, 01:48 AM   #20
Losi Chaser's Avatar
R/C Tech Charter Subscriber
Check the spur gear and pinion for a burr or small chunk in between the teeth. It's a good chance there is some grit between the teeth.
Losi Chaser is offline   Reply With Quote
Motor Upgrade Sweeney921 Rookie Zone 8 01-30-2007 07:37 PM
F/S RC10T4 with battery and motor Sluggo R/C Items: For Sale/Trade 40 08-20-2006 11:40 PM
Motor upgrade e-g33k Rookie Zone 13 11-30-2005 12:31 AM
Motor/RC10T4 coolguy5 R/C Items: For Sale/Trade 6 08-24-2005 09:39 PM
XXX-S Motor Upgrade Losifreak Electric On-Road 1 08-22-2004 11:13 PM
