Old 05-09-2007, 07:06 PM   #1
Default What is Off/On Power Push? Loose Off/On Power?
http://www.rcinfusion.com/Help.aspx
I was reading this and dont understand it. Can someone pls explain in laymans terms. Thanks.
Ken4 is offline   Reply With Quote
Old 05-09-2007, 07:48 PM   #2
Warhawk 1's Avatar
I didn't read the article but here is a very brief explanation of those terms. On power push means that you have the throttle pulled and are giving power to the tires while attempting to turn. Its pushing because the front tires are not gripping. The rear tires have more traction than the front. You need to let off the throttle to cause weight to transfer to the front so that the car will rotate thru the turn.
Loose on power simply means that when giving throttle and attempting to turn the front maintains grip and the rear end looses traction and rotates around. Less skilled drivers will probably not be able to control this setup. But for skilled drivers this setup is faster. Its easier to control a car that is setup to push.
I hope this helps.
Warhawk 1 is offline   Reply With Quote
Old 05-10-2007, 01:09 AM   #3
Thanks for your expert explanation!
Old 05-10-2007, 05:59 PM   #4
Warhawk 1's Avatar
You got it...
Power Push Batteries ground-round Team and Company Discussions 745 06-18-2016 02:32 PM
power push batts. are the way to go!!!! L3Jay Electric On-Road 6 01-11-2005 11:58 PM
Power Push batteries are the way to go! L3Jay Oval, Larger Scales and More 0 01-11-2005 07:18 PM
FS:Power Push GP3300 NEW!!! rayhuang R/C Items: For Sale/Trade 1 04-15-2003 08:56 PM
FS:New 1.16 and 1.17 Power PUsh GP's rayhuang R/C Items: For Sale/Trade 0 04-09-2003 09:24 AM
