What Motor?
Hi, buying a Tamiya DF02 chassis kit (gravel hound) from tamiya, was wondering what motor i should put in there for general off road/beach/bashing was thinking of an 9turn motor (http://www2.towerhobbies.com/cgi-bin...?&I=LXLRE2&P=0) would this be any good? will be running the Novak GTX limitless ESC
Thanks for any help, Danny |
Danny,
I would personally have looked at a brushless setup since the motors are sealed and beach running would have worked much better then. A 9 turn is pretty hot motor, can the chassis handle it? If so, I would go with a checkpoint or trinity shock motor. something that doesn't gum up in the dust (V2s can gum up in the brush hoods) and gets long runtime between motor comm cuts. Ultimately, a brushless setup probably would be best. Assuming the cost of the GTX and a checkpoint motor, not too much price difference than just getting a Mamba max system. And you will need a lathe for the checkpoint still. |
ok i will have a look at the brushless motor systems, with the brushed motors what would the difference be with a 9t and something like a 15t ?
am i right with 9t has higher top speed and more torque and the 15t has faster acceleration? |
Lower turns = higher top speed, less low end torque
Higher turns = more low end torque, less top speed |
thanks nemix
the gravel hound has been ordered today :p should have it by monday :) the motor and ESC will be ordered on thursday next week, i think im going to get a 10t motor, the motor will be switched from my TT01 to my DF02 depending where i am/what im doing, the DF02 will be used on the beach (only when im on holiday) otherwise mainly on dirt/gravel and my TT01 is an all rounder :p |
since you dont race i would look into a mamba max 4600. will give you more run time and is sealed. wont eat brushes up as it doesnt use any!
what is the diffence between the 4700 and the 5700/6700/7700 ? are they different speeds?
sorry im a noob when it comes down to rc cars :lol: |
You might check out some of these?
Every thing you need all in one company. http://www.shopatron.com/product/pro...51.17441.0.0.0 Here's mine. :D Lipo and motors. Every speed you need from slow to blink. :nod: |
Yes, that is correct. I don't know the exact way it breaks down, but in general terms, the way you listed it is correct.
Heres a variety of motors. The lower the number the faster it is.
The slower motors provide more run time, the 5.5 or 6.5 might be perfect for bashing. http://www.shopatron.com/product/pro...51.17441.0.0.0 Great products. |
the numbers on the mamba max are rpm per volt. the higher the number the faster it is. speed control can be programed by hooking up a usb to your computer and its 50 or more dollars less expensive than novak or lrp. only thing is though they are sensorless so they are not roar race legal
not too fussed about racing, i think im going to get the mamba max 5700, i think that will suit my DF02 and my TT01 for bashing, ill probaly buy a novak system when i get some more money, just want a decent motor before i go away :nod:
if you arent gonna race i think the mambas will be at least as fast as anything out there that is sensored besides all you would need to do is get a bigger mamba motor
do you have to "break in" a brushless motor? :blush: im such a noob
