Old 05-07-2007, 06:07 PM   #1
Dougg's Avatar
Default Just ordered LRP comp/5.5 brushless combo for xx4
I run a Cavaleri 11x1 in my xx4. I'm very comfertable with it. I just ordered a brushless setup. My question is gearing the motor. I now run 86/17 for my ratio. (small track) What gearing should I try on this thing? I never use this car for backyard bashing. Only sees a track. I accually wanted the 6.5 setup, but it doesn't come with the comp speed controler. I figured that I can de-tune this motor to be managable.
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 05-07-2007, 07:32 PM   #2
Doug,
Buy a 6.5 motor......I dont think you can de-tune the motor enough. The 6.5 has a ton of power. The optional "Sintered Rotor" makes it feel like a brushed motor.
-Scott Spear
Team Associated, Reedy, LRP, Proline, Winning Edge Designs, Byrons Fuel, AVID Bearings, TFR Racing. ***Team Associated Region 10 Administrator***
Scott S. is offline   Reply With Quote
Old 05-07-2007, 08:19 PM   #3
Dougg's Avatar
The 6.5 is the motor that I want, but knowone has a 6.5. I guess I'll have to wait for the motors to come in. I'll bust a few A-arms wile I learn.
Doug
Old 05-07-2007, 08:24 PM   #4
Trader Rating: 91 (100%+)
I run a GTB/sintered 5.5 in my XX4 geared at 15/84, I could probably gear up with no problems if I needed. The LRP should be pretty close to the Novak stuff.
Eric Tomczyk is offline   Reply With Quote
Old 05-10-2007, 07:33 AM   #5
dan r's Avatar
i'm running the 7.5 in a buggy.. what's a safe temp for the motor? thinking about going up a tooth, the esc doesn't get hot, the motor is pretty warm though.
TLR/Nitrotane/Spektrum/Orion/Horizon Hobby/CR Graphics
dan r is offline   Reply With Quote
Old 05-10-2007, 07:51 AM   #6
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I try to never gear over 130 to 140 degrees with any motor.
Perfect performance range with any electric motor.
UN4RACING is offline   Reply With Quote
Old 05-10-2007, 08:47 AM   #7
140 is a good limit. I think it will thermal at 180, I know mine runs at 165 on big outdoor tracks on a hot day.
Old 05-10-2007, 01:54 PM   #8
mfishel's Avatar
I've been running an Lrp Comp. in my B4 for a while, and just moved it into my BJ4 last week. I have been running the old Neo One Three Star, it's a 6.5. It seemed just slightly over powered in 2wd. Not bad though. My advice would be to find one of those. It'll be cheaper and I know they are available.
mfishel is offline   Reply With Quote
Old 05-12-2007, 10:56 PM   #9
Dougg's Avatar
Ok! 12/86, that is the gear ratio I ended up with. I feel that I need to drop to a 11 tooth pinion. Or has anybody tried an 88 tooth gear? I had to do some dremal work to the chassis to get the 86 tooth gear in. THe 12 tooth pinion is very noisey. I thought that the brushless would feel completly different. It doesn't,,, I don't run drag brake in mod brushed. But, I was told that I will need to run some with the brushless to feel the same. I didn't need any. It feels completly the same as brushed. I didn't find the 5.5 difficult to drive at all. I thought that it would be too much motor for me. Not at all. Motor got to 133 degrees, the speed controler never got over 130 degrees. I think it is geard right, but I want a little,, little more punch. I'm going to try to get the 88 tooth in. Will see what comes of this. Thanks for the input.
Doug
Old 05-13-2007, 10:21 AM   #10
jk racing's Avatar
Trader Rating: 20 (100%+)
Dougg, I would attempt to actually gear up a bit. The torque on brushless motors is different (in my opinion) and can take more gear. I run the GTB/6.5 in my XX4, and I am geared 20/84. Has enough punch to clear everything, and ballistic top speed. I have never thermalled, and run in the 100~120 temp range (on my temp gun anyways).
In my Academy SB V2 (same internal ratio as the XX4), I run a Mamba Max 4600, geared 19/78. Very punchy still, and great top end.
I personally have found that my older batteries are way to "soft" to run brushless, no punch, no top end, poor performance. But when I use them with a brushed set up, the difference was minimal. When I drop in my new 4200's, hold on.... The motor wakes up and delivers.
I will attempt to contact one of the guys I race with, he runs a 4.5, 5.5, 6.5 in his XX4, and uses the 86 spur. His car is always punchy and tons of top end. Funny watching him drive around Truggies on the big tracks.
--Joey--
Venom Batteries & Chargers
Old School Racer & Vintage RC Car nut
jk racing is offline   Reply With Quote
Old 05-13-2007, 10:54 AM   #11
Dougg's Avatar
I would like to hear what youre friend uses. I started with a 16 tooth pinion, (same as my 11x1) The motor had nothing. If there was a 100 foot straightaway, it would have been perfect. We only have a 30 foot straight. My batterys are 1.24's 4200's. I then started to go to smaller pinions from there. I would like to hear your friends setup. My 11x1 was a little faster, I have a motor tunner that gets it to act like a 8 turn. So I was expecting the 5.5 to feel the same. Oh well. let me know about youre friends info.
Doug
Old 05-13-2007, 02:55 PM   #12
jk racing's Avatar
I just got off the phone with him, for the 4.5=13, 5.5=15, and 6.5=18. Our straights are quite a bit longer here in southern cali, so maybe your 12t is good.
Batteries like that should sling the tires off the wheels!
--Joey--
Old 05-13-2007, 06:01 PM   #13
Dougg's Avatar
thanks
Doug
Old 05-13-2007, 07:31 PM   #14
wallyedmonds's Avatar
tell us if you get it and where did you order it and
good luck cuz i still cant get one
x11 007 combo 5.5
in my zx-5 i run 17-78 with a mamba 5700 (like a 9t)
and i think the 5.5 is like a 9t too.
wallyedmonds is offline   Reply With Quote
Old 05-13-2007, 10:22 PM   #15
Dougg's Avatar
https://www.ssl-stormerhobbies.com/c...ns&pn=LRP80598
Stormer hobbies has 5 in stock. It was the comp 07.
Doug
Looking for brushless combo davy630267 Australia Wanted to Buy 0 03-21-2008 03:50 AM
wtb: mamba max combo or any brushless esc:motor combo mrbrnz Australia Wanted to Buy 0 10-10-2007 07:57 PM
Brushless combo hirosaki R/C Items: Wanted to Buy 1 09-14-2007 02:05 PM
LRP Sphere Comp w/ NEO-One 4 Star Brushless system combo yyhayyim R/C Items: For Sale/Trade 3 08-05-2006 07:37 PM
FS: X-ray M18 with brushless combo cnk R/C Items: For Sale/Trade 11 11-21-2005 10:46 PM
