Old 05-05-2007, 09:09 AM   #1
eziduzit's Avatar
Electric Guy goes Nitro...help!
So my first nitro newbie question....
While trying to break in a new motor I'm killing my glow plug warmer. So I threw in one of my team matched cells, 4200mah. Everyone seems to love the idea and everyone is now using my warmer, so it dies much quicker than if I were using it alone.
The question is... how can I use my Duratrax Ice to charge just a single cell and what settings would I use? (Charging a pack I'd be charging at 4.2 amps, not sure if that would work for the single)
Next question.. should I be charging several at a time to have reserve batteries? Should I build a tray to make this happen?
Thanks for any help!
Ezi
eziduzit is offline   Reply With Quote
Old 05-05-2007, 09:44 AM   #2
If you're killing your glow igniter trying to start your new engine during break in you need to either get a better engine or retune the one you have. It shouldn't take much to get it started so you shouldn't have any problems with your glow starter battery. Oh, and regardless of what your mom said, don't share.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: [email protected]
satoch is offline   Reply With Quote
Old 05-06-2007, 11:07 AM   #3
eziduzit's Avatar
No one knows about the charging of a single cell?
Old 05-06-2007, 12:01 PM   #4
TGA78's Avatar
Do you have a charger that can charge at the voltage of a single sell? If not then your going to have to rig something up to charge and discharge enough cells to meet the minimum voltage of your charger.
TGA78 is offline   Reply With Quote
Old 05-06-2007, 12:14 PM   #5
Send a message via AIM to GroffBall
The ice will charge a single cell just change the number of cells to 1 in the charge screen I charge my 10,000mah D cell for my glow igniter on my Ice with no problems.
GroffBall is offline   Reply With Quote
Old 05-06-2007, 12:37 PM   #6
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
I use old cells to do this - so it may not be something you want to do. If I'm charging my single 3800's up for my ignitor... I charge it at 6 amps and never have an issue. Though normally I wait until I have 6 dead ones... solder them up as a pack... and charge them all together - at 6 amps.
XMSRacing is offline   Reply With Quote
Old 05-07-2007, 07:49 PM   #7
eziduzit's Avatar
I was hoping to avoid having to build a stick pack just to charge one battery. Is there no other way?
Ezi
Old 05-08-2007, 10:16 AM   #8
Using your ICE charger, just select 1 cell and charge at 6amps. YOu can just tape the connectors on each end of the batterie. I did it and it is working just find.
AE MGT .21
GS Storm
AE RC18MT
AE RC10 B4
falconcg is offline   Reply With Quote
Old 05-08-2007, 11:34 AM   #9
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
If you are using the cell in one of those rechargeable glow ignitors and are just wanting a faster charging, you can always cut the charge cord leads and right it up to work with your charger. Much faster than wall charging.
I would look and see if your glow plug could be going bad.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 05-08-2007, 11:51 AM   #10
Trader Rating: 42 (100%+)
Good luck, I had nothing but headaches with nitro. We only race electric now, cleaner and quiet. Wait until you get that oil on your shirt.
desertraton is offline   Reply With Quote
Old 05-08-2007, 06:17 PM   #11
RBMike's Avatar
Eziduzit: Wear an old shirt.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 05-18-2007, 09:12 PM   #12
eziduzit's Avatar
Pretty funny RBMike!
6 amps sounds like a lot. That cell must heat up something fierce.
I thought the rule of thumb was to just divide by 100 and that's the amps you use? In my case the cell I'm using is 4300mah, so I'd charge at 4.3 amps.
Old 05-18-2007, 09:35 PM   #13
that is old school, most batteries over 3600 are now charging at 6 amps, aat leasy for racing. wierd, I can run my 1800 igniter allday on one charge. try to keep your igniter on teh charger when you are not using it, and that should help. Also, having 2 igniters helps remendously as well. A great way to get your new nitro engines started is to heat it up to between 180-200 degrees with a hair dryer or heat gun first.
HTH
Rod
gatermaxx is offline   Reply With Quote
Old 05-18-2007, 09:40 PM   #14
wallyedmonds's Avatar
get a dynamite ni-charger
you plug your glow igniter in it and it quick charges it
its nice and easy.
wallyedmonds is offline   Reply With Quote
LOOKING TO BUY RC NITRO TRUCKS, CARS, BUGGYS, ELECTRIC OR NITRO CASH IN HAND jd267 R/C Items: Wanted to Buy 26 09-06-2008 12:25 PM
Nitro Vs Electric stoptherockets3 Electric On-Road 2 01-23-2008 06:01 AM
ct rc nitro or electric jombo Nitro Off-Road 2 01-14-2008 08:23 AM
WTTF: mini electric or nitro (nitro perfered) and also looking at all nitro deals.... xxx-ntad2 racer R/C Items: Wanted to Buy 3 04-25-2007 07:53 PM
