Help with set up and Assemble XXX-T MF2
OK well I went and got my truck today. I also got Pink Yellow and Orange springs. I am looking for a set up with pretty high traction on a almost clay compound. Please Let me know.. I am excited to put this thing together.. Any other suggestions or advise in assembling please let me know...
not impressed
WOW so far I am not impressed with the way things fit together on this truck There are flaws from the moding all over.. I have heard that losi is known for that but wow... Maybe I am just to used to my carpet car (007)
flaws
#1 The screw holes almost have to be redrilled to fit the screw thru to get to the treads
#2 on step A5 inserting the treaded inserts for the steering. I had to take a rubber malet to get them in far enough so the "kick plate" screws would attach to the chassis
#3 The A arms. there was about a 1/8th inch piece of extra casting I had to grind down....
SO far I dont mind I think its fun. but for the price one would think it would come with a little better machine work/ moldings
The other insert is tough as well, but its also necessary seeing how the entire front end relies on those 2 screws for flex on the top.
A arms, thats about normal, again offroad you see a lot more wear, so things arent of a tighter tolerance compared to onroad. Once you put it on the track all the tolerances go out the window for the most part.
