Old 05-02-2007, 01:15 PM   #1
Anoobis's Avatar
Default JRX Pro S.E.
My apologies if this information is widely available but I don't have time to search the forums (at work).
I've got an old Team Losi JRX PRO S.E. with the XX tranny and Hydra Drive. The car is in pristine condition. I only ran it about a dozen times before shelving it. I sort of lost interest in the hobby.
Well, I'm looking to get back into it but I think I'll just stick with this car for now. I'd like to know if there's a place that still sells parts for it. Mainly the tranny but I'm sure the shock cartridges are in need of replacement too. The tranny still feels butter smooth but I was curious to know if parts were still available for it (diff balls, rings, etc.)
I've been out of this hobby since pre-2000. I hail from the days when the name Masami Hirosaka struck fear in the heart of many (for all I know he still could) so any changes with tech like batteries, motors, radios etc would be helpful too.
Thanks all.
Anoobis is offline   Reply With Quote
Old 05-02-2007, 01:23 PM   #2
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
ebay is your friend i have an losi lxt and a losi gtx and so far ebay and alot of searching google. good luck in your rebuild
cheesecake is offline   Reply With Quote
Old 05-02-2007, 01:32 PM   #3
Registered User
A car like that should stay on the shelf, that would be an awesome shelf queen really. For a little investment you can buy a XXX-CR which will be much easier to find parts for. Should you break an arm or something do you really want to be scrounging around eBay while your out of racing? Should you get back into it you'd find it highly annoying I think to be stuck without parts that would be readily available for a newer car.
The investment is minimal, for less than $200 you can get a XXX-CR. Personally I'd clean up the JRX PRO, put a cool car stand underneath it and put it in my display case.
Desolas is offline   Reply With Quote
Old 05-02-2007, 01:37 PM   #4
Mytimac's Avatar
Parts are getting harder to find for these.
Best source for parts is old hobby stores with old stock hanging around and ebay.
As far as rebuilding the shocks, you can use the cartridges used in the modern buggies.
The outer transmission housings for the xx retrofit are like gold on ebay.
The diff rings are used in the modern stuff still. http://www.horizonhobby.com/Products...rodID=LOSA3070
The Diff Thrust balls are all standard parts available from all sorts of companies. Diff 3/32 and thrust 1/16.
The Diff gears are still available.
It is the arms, chassis, shock towers and such that are getting harder to find.
You can still get bodies (not losi brand) from http://www.vansinvent.com/ . The bought out Dahms a few years ago and continue to offer bodies from the old molds.
Owner:
Vintagelosi.com Lots of info on Team Losi JRX2, JRX-Pro, LX-T, and XX buggies and trucks.
Oldrc.com Resources for many older RC models.
Sabulatech.com vintage RC parts store.
Mytimac is offline   Reply With Quote
Old 10-04-2008, 01:40 PM   #5
Sorry if this has been asked before...couldn't find anything using search. Anyone know where I can find a manual for the Pro SE?
slopo is offline   Reply With Quote
Old 10-04-2008, 07:36 PM   #6
Super Moderator
Start here:
http://vintagelosi.com/Manuals.html
You have to use the Jrx-Pro and the SE Addendum. There isn't a dedicated Pro SE manual. Possibly the XX retro tranny manual too depending on what ya got.
I agree that you shouldn’t plan on doing anything beyond an occasional easy fun run with something this old, many parts aren’t available.
If you want to give it a go again at low cost, there are lots of relatively cheap used XXXs available that can still be repaired and updated.
Dave H is offline   Reply With Quote
Old 10-04-2008, 11:39 PM   #7
Yeah, I've been to vintagelosi. The addendum really doesn't help me, but thanks.
Old 10-05-2008, 12:02 AM   #8
JeromeK99's Avatar
If you want to get back into r/c.. I'd say sell it! You should be able to get enough to buy a new losi buggy.. probably a XXX BK1 or BK2 which still has parts available and even shares some of the newer CR parts...
I've seen good race rollers going for around $100.. many less. these are still top level buggies and are often preferred over the newer CR.
Good luck!
Jerome
JeromeK99 is offline   Reply With Quote
Old 10-05-2008, 04:36 AM   #9
Super Moderator
How can I help? I still have all of the manuals, parts listings, the car, both trannies, etc.
Old 10-06-2008, 09:11 PM   #10
Cool. Thanks. Is there a spacer between the rear bulkhead and rear shock tower like on the LXT? Also what size/type of screws are used on it? I'm assuming flat head, but not sure of the exact size.
Old 10-06-2008, 09:49 PM   #11
Good luck!
Jerome
Why do people prefer the bk1, bk2 over the new cr? For what I have heard the cr has more traction, better steering, and easier to drive than the bk2. That must be why there are soo many people selling them.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 10-07-2008, 12:38 AM   #12
JeromeK99's Avatar
If I remember correctly, the spacer was only on the LXT truck.. The chassis screw size is 10-32... both Losi and Associated used these in there cars.. mostly made of aluminum.
Jerome
Old 10-07-2008, 12:40 AM   #13
JeromeK99's Avatar
Chris,
A lot of people still like the older BK1 and BK2 because both the plastic and graphite parts are much better than the EA3 plastic. This along with just about every metal part.. the new cars have lots of "Made in China" components. Losi used to be a step above the rest.. now they are just the same as everybody else when I comes to quality of parts. Still all good cars.. just not better anymore...
Jerome
Old 10-07-2008, 07:51 AM   #14
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Chris,
Jerome
I totally disagree with that .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-07-2008, 09:57 AM   #15
Mytimac's Avatar
It is in the manual, just no fancy pictures.
Page 1 to be exact. In the addendum.
Fig 2 is the section.
In summary, you should mount the bulkhead all the way forward and not use the rear mount holes. This means you don't need the spacer, unless you want longer wheel base.
That being said, modern nimh batteries are a pain to squeeze in the chassis unless you hack the front battery strap area or mount the bulkhead farther back and leave out the spacer. (not sure on a lipo)
Owner:
