Old 05-01-2007, 12:58 PM   #1
Default gt2 motor
i need a .12 sg shaft with rotary carb
a main shows a o.s. tg12e rotary carb and desciption says it has a pilot shaft which is same as a sg shaft but picture has a different shaft shown so which one is it
i also find a dynamite platinium .12re sg rotary carb off road it has a rear output
do i need a motor with a side output or a rear output
dirtywater is offline   Reply With Quote
Old 05-01-2007, 05:17 PM   #2
raydog's Avatar
Trader Rating: 150 (100%+)
You can use a standard shaft on the GT2. You will just need to cut the crank and use the TC3 clutch nut.
-Raydog
Team Associated - Reedy - Schelle Racing - Pro-line Racing - Upgrade-RC - Thunder Designs
www.StickyKicksRC.com - R/C Tire Conditioner and Traction Compound
raydog is offline   Reply With Quote
Old 05-02-2007, 03:58 AM   #3
MaTt 93's Avatar
Send a message via MSN to MaTt 93
LRP Z.12R Team Truck Engine. Thats the engine you want
http://rc10.com/lrp/engines.htm
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 05-02-2007, 07:50 AM   #4
Default gt2
i would rather use one of the other two motors bacause i dont have to do any cutting
Old 05-02-2007, 08:31 AM   #5
Trader Rating: 27 (100%+)
Send a message via Yahoo to HECTICRACER
i got a tz all cut and ready to go it has 2 carbs the stock 1 and the 10e witch allot of factory drivers are using let me know if your intrested
HECTICRACER is offline   Reply With Quote
Old 05-02-2007, 10:08 AM   #6
raydog's Avatar
Most .12 motors that have an SG shaft and a slide carb will be an on-road mill so check the porting on the motor. You definitely want an off-road motor for this truck. Trust me, I tried an on-road mill at first and it was no bueno'
-Raydog
Old 05-02-2007, 08:21 PM   #7
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
would an OS CVR 18 be too much a motor for this truck? not into racing but just bashing around at the local 1/8 buggy track. thanks...
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 05-02-2007, 08:24 PM   #8
RCBLUE's Avatar
I would say absolutely yes. I am running a .12 TZ and it is too much, but sooo much fun.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 02:17 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
