MBX5-R rear end loose, any good setups out there?
Having trouble getting my rear end to hook up at the track. Made a few changes and they have helped, but I'm still fighting the car on turns and straights. Anyone have a good setup for a Mugen MBX5-R?
Thanks.
Thanks.
Make sure your rear droop is about 30mm greater than your front...also, raise the rear ride height to bones level or slightly above level and set your front ride height to bones lust below level.
rear hubs all the way back (all spacers in FRONT of hub)
2.5 rear toe
rear camber link parallel to lower arm
middle hole in rear anti-squat plate.
2.5 rear toe
I think you mean 3mm? 30mm is almost half the total travel of the suspension. Also, use the 3*rear block instead of the 2.5. It will give better control on power.
Check your anti-squat! Give us your setup also. I'm shooting in the dark until I see that. By the way my car is dialed!! Love this car!!!
5-7-2 diffs as well. That should help alot.....
Tires right for track? Diff oils? these are the 2 big ones.
My mugen setup
The buggy handles the bumps pretty good, but the rear end loves to kick out while accelerating out of turns and in straights. If the track dries up a bit then forget about it, the buggy is very sensitive. There are a few people using crimefighters at my local track with good results, but Panther Kamodo Dragons seem to be the majority so I may give 'em a try.
Let me know what you guys think. Any input would be helpful.
What track are you running at?
Tracks
106, templeton, but mostly RCE
I am having the same issue.
If you raced at RCE this past Sunday, the track was really bumpy which may explain the loose rear end. What tires are you running? Crimefighters and Cubics might be a good choice.
Did you happen to catch the Buggy A-Mud race last Sunday. I haven't seen one of those in a while.
