Old 05-02-2007, 09:47 AM   #16
Tech Legend
Wild Cherry's Avatar
Originally Posted by DUB_Ben
The best gule I have used is Pro-Line. It is a little pricey. But its worth it.
Think it is the same glue as Losi`s ...
Comes in the same bottle too, cept the Losi costs less....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-02-2007, 05:49 PM   #17
Any fresh THIN super glue/CA. The glue doesn't matter so much as long as it's fairly fresh. I have no idea how people use the medium or thick stuff....
Prepping the tire and wheel is far more important...... get both really clean.
AE FT B44.2, SC10, T4, B4.2, B4, 18T, 18R, TC4, L3.5O ** Losi MRC Pro ** CRC Carpet Knife ** Axial XR10, AX10, SCX10 ** Traxxas EMaxx ** JR Z1
Manning is offline   Reply With Quote
Old 05-04-2007, 05:34 AM   #18
Chevy-SS's Avatar
Two things that matter for gluing tires:
1) prepping the tire and wheel - scuff and then clean
2) application of glue - you need a solid bead of glue all the way around the tire. If there are any gaps in the contact area, then the tire will eventually work loose from the wheel. Best way I have found for a consistent bond is to do step 1 above, then mount tire and foam to wheel, getting the tire PERFECTLY mounted on the wheel. Now, peel up a small section of tire at a time, stick CA glue nozzle in there and apply a few drops. Re-seat the tire so that it's PERFECT, then quickly move to adjacent section of tire and repeat process until done. I move around the tire about 1/8th way each time. I use medium CA glue, which flows around the wheel.
It takes a few tries to get just the right amount of glue. You need enough to form a strong bead all the way around the tire. Too much glue will just make a mess. You need to start with the tire perfectly mounted and you need to re-seat it perfectly each time you lift to apply glue.
Chevy-SS is offline   Reply With Quote
Old 05-05-2007, 09:29 AM   #19
MUCH MORE
lineburner is offline   Reply With Quote
Old 05-08-2007, 06:03 AM   #20
what about Kyosho CA glue?? anyone use it?
vasileios is offline   Reply With Quote
Old 05-08-2007, 04:07 PM   #21
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
+1 for the Loctite 406, simply the best glue on the market, you have to be carefull with it though, as it bonds TO GOOD sometimes, if you reuse the rims simply soak them overnight in some acetone as it disolves the CA and is safe on the nylon wheels, trust me you wont be peeling the tyres off if you use the loctite glue, onky acetone will get them off.
NJA82 is offline   Reply With Quote
Old 05-10-2007, 01:47 PM   #22
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
i use a loctite super glue but is there something else that won't harden on contact with the rubber like the super glue does? sometimes the tire doesn't perfectly fit into desired space and the superglue hardens very fast. any suggestions on maybe a slower setting material. thanks in advance
Bulldawg RC is offline   Reply With Quote
Old 05-15-2007, 11:55 AM   #23
K.Lock's Avatar
Originally Posted by theanimaleide
Team losi thick
i have to agree losi glue is the best....proline glue sucks
K.Lock is offline   Reply With Quote
Old 05-15-2007, 07:58 PM   #24
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Where can you get Loctite 406?
Dasupacat1 is offline   Reply With Quote
Old 05-16-2007, 07:14 AM   #25
PTP Racing's Avatar
Ive never used the loctite stuff but the fusion tire glue works really well. I love the way just a drop can do a large section of a tire and it drys so quickly I dont get glue on my hand as I work my way around. I'm curious about the loctite stuff but the fusion works so good I doubt I'll go out of my way to find it.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-16-2007, 07:16 AM   #26
PTP Racing's Avatar
I also dremel the tire bead till its got no bad spots or extra rubber and use denatured alcohol to clean the wheel before glueing. The prep work is more important than the glue you use.
Jason Miller
Old 05-16-2007, 07:28 AM   #27
foolio's Avatar
Gotta say, Pro-Line Glue has been nothing short of excellent for me. Used Losi and Loctite as well, both good glues. It's all in the application and prep.
foolio is offline   Reply With Quote
Old 05-16-2007, 07:57 AM   #28
GymBeam's Avatar
#1 Muchmore, you actually get a full bottle. great value for money
Fusion is too thick.
Proline works good but you dont get much for the $$$. Its only 1/2 full
GymBeam is offline   Reply With Quote
Old 05-16-2007, 08:51 AM   #29
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
best vid to show you how to do it for the first time http://www.youtube.com/watch?v=_vmWf...o%5Fhelp%2Ehtm
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-16-2007, 11:03 AM   #30
K.Lock's Avatar
were can you get the team muchmore glue at?
tires n glue tooyhycriters Nitro Off-Road 7 01-26-2008 03:05 PM
How can I glue foam tires? bbfwd Electric On-Road 15 07-22-2006 05:12 PM
Brand New Buggy Tires, Rims, Proline Glue, OS Plugs Michael_T Australia For Sale/Trade 1 03-12-2006 03:16 PM
Can I use ELMERS glue to glue my tires to the rims? Jhyten Electric Off-Road 20 02-25-2006 11:49 AM
Super Glue for Tires taybelZ Electric On-Road 25 11-13-2002 09:37 PM
